01-04-2012, 02:05 PM | #1 |
Rock Crawler Join Date: Dec 2011 Location: Northwestern PA
| Your opinions on two servos
I have an AX-10 RTC. I'd like to have a greater range of steering. I already made my own tie rod that adds a little toe-out, and now I'm looking at servos. Can you tell me what you think of these two servos? Henge MD260 180-260 degrees Metal Digital Servo for FPV pan tilt control MD180 S | eBay SR403P 180 Degree Metal Gear Robot Servo Double Bearing | eBay Thanks, Josh |
01-04-2012, 02:21 PM | #2 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
| Re: Your opinions on two servos
Hey Josh, Actually a longer swing servo is not really what you need. I see in your future is serious binding issues. I would suggest a High torque servo and some quality High clearence Knuckles and some C-hubs with additional caster angle. You may want to consider a Behind the axle steering set up. You have a Axial so my information is based on Axial design axles. Just my 0.02 . Last edited by DRV KRAWLER; 01-04-2012 at 02:22 PM. Reason: edit |
01-04-2012, 02:24 PM | #3 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
The robot servo has outputs on both sides and no ears on the case so you would need to modify your servo mount. The other one has a low torque rating. There are others in that price range with a lot better specs. Have you tried a longer servo horn? |
01-04-2012, 02:55 PM | #4 |
I do not have an aluminum servo arm, but I did super glue the servo saver so it is solid. I have an aluminum arm on the way; it should be here in a few days. I do have aluminum steering knuckles already installed. I set up the suspension so there is a very slight amount of caster. I just want to have more steering. I want the steering knuckle to hit the screw on the c-hub when I turn the whole way in one direction. Any advice is appreciated. Here is a link to a few photos I took so you can see my set up and what is going on: AX10 steering - a set on Flickr |
01-04-2012, 03:19 PM | #5 | |
| Re: Your opinions on two servos Quote:
Take your tie rod off, push the arm against the screw head, and then turn the tire. You will feel the bind. | |
01-04-2012, 03:24 PM | #6 | |
01-04-2012, 03:33 PM | #7 | |
I like the Hitec 7955TG because it is a good bang for the buck servo. 333 oz/in of torque at 6V and only $109. Any 3/4" servo horn should work well, I even use the black pastic one that comes with the Hitec servo, on my 1.9 top truck rig. Oh, and you need a CC Bec to run that stronger servo because of the amps it pulls. Servos and accessories*-*-Electronics*-*The Crawlers Store LLC | |
01-04-2012, 03:52 PM | #8 |
Awesome, that's great info. I actually do have a CC BEC....forgot to mention that above. Thanks!
01-04-2012, 04:41 PM | #9 |
| Re: Your opinions on two servos |
01-04-2012, 04:49 PM | #10 |
It doesn't take much to touch the screws on the axials. The arm in the pic doesn't look to short but it's hard to tell in the pics. Do you have a way to adjust the steering throw or EPAs on the TX.
01-04-2012, 04:52 PM | #11 |
Rock Crawler Join Date: Nov 2009 Location: poteau
go to the ax10 section and look at my thread "steering angle" it will give you lots of tips and tricks.
01-04-2012, 04:57 PM | #12 |
| Re: Your opinions on two servos The transmitter is a little basic, as it is the one that came with the RTC package. It does have an adjustment to turn up or down the amount of movement the servo has, and I have it turned all the way up. The servo seems to have about 90* of total movement.
01-04-2012, 06:31 PM | #13 |
| Re: Your opinions on two servos Ok a longer servo arm will get you where you want then. As mentioned above if it binds you can open the end of the cup up a little with a dremel tool to smooth it out.
01-04-2012, 07:17 PM | #14 |
Newbie Join Date: Dec 2011 Location: Erda, UT
If that picture is full lock, you need to change your steering knuckle, so that the arm on the knuckle sits 90* perpendicular to the axle when the truck is pointed straight, the way it sits now its at 45*, sooo the maximum amount of travel regardless of axle bind is only 45*. If the arm were 90* to the axle, then you could have up to 90* of travel. Did that make sense ?
01-04-2012, 08:02 PM | #15 | |
01-04-2012, 08:10 PM | #16 | |
The angle of the connection points has some bearing on the amount of steering, but once "hard parts" hit something else, all movement stops. What you are describing is Ackerman angle, that has more to do with what each steering tire does relative to the other steering tire when you move the steering servo. The link angle from the servo arm/horn to the knuckle attach point has some relevance as well, but is also separate from Ackerman angle. Josh, if you disconnected the steering stuff from the knuckle, the max steering angle you could get is based on when hard stuff hits other hard stuff (or, you max out your flex joint of the axle within the steering knuckle). | |
01-04-2012, 08:23 PM | #17 |
Ok that makes sense. My problem is that hard stuff is not hitting that other hard stuff. Maybe I need a longer servo arm. Seems like the whole steering system needs more movement.
01-04-2012, 08:36 PM | #18 | |
Keep in mind that if you double the arm length, you ~halve the torque available. Hey, it's engineering, typically when you fix one thing, you FUBAR another. Make sure the steering moves freely with the servo disconnected. If not, fix that 1st, then move on to more travel from the servo (maybe a longer servo arm/horn). | |
01-04-2012, 09:26 PM | #19 |
| Re: Your opinions on two servos I disagree, and here is why, the arm(part that the tie rod attaches to on the knuckle) will only turn to 0*, which is where the arm is at now at full turn. Adding more movement on the servo end won't make the knuckle turn past 0* Try disconnecting the tie rod from the servo and cycling the steering on the same plane as the servo, if you do, please take pictures so we can all see. Adding a longer servo arm will increase the turning rate of the steering, and if the steering geometry were better, would increase movement.
01-05-2012, 01:15 AM | #20 | |
Good eye newbie | |
Your opinions on two servos - Similar Threads | ||||
Your Opinions, Please | XtrmTJ | Newbie General | 3 | 02-22-2012 01:01 AM |
opinions on tower pro mg995 servos | jedsled | Electronics | 8 | 05-03-2008 11:34 PM |
need some opinions | mrmaxxman | 2.2 Scale Rigs | 10 | 05-05-2007 11:03 AM |
