01-06-2012, 03:57 PM | #1 |
Newbie Join Date: Jan 2012 Location: Beloit
| Full size servo on Losi MRC? Power supply Upgrade?!
I'm just wondering if i can run a full size servo on my Losi MRC with stock ESC N Batt??! I've got it all set up but dont want to fry aNother speed control... had pretty bad luck on some of my other rigz... Any help on this would b GREAT! Thanks to all for looking!!!! |
01-06-2012, 04:01 PM | #2 |
| Re: Full size servo on Losi MRC? Power supply Upgrade?!
Depends on the servo. Up to 200/250inoz, you likely are OK, above that gets questionable. What some do is to run the red & black wires from the servo to the wires from the battery to the ESC (if you are using a 2S LiPO). An alternative is to use an external BEC like a CC 10A BEC to feed the servo direct. What servo are you looking to run? Did you look in the MRC forum?? Depending on your radio, make sure the steering EPA's are set correctly, not stalling the servo because it's being driven too far. |
Full size servo on Losi MRC? Power supply Upgrade?! - Similar Threads | ||||
LOSI Carbon Fiber servo / lipo mount - any PICS with full size servo? | mascman | Losi Mini-Rock Crawler | 10 | 12-16-2009 08:35 AM |
Seperate power supply for servo?? | DORK VADER | Electronics | 7 | 01-11-2009 04:51 AM |
MRC Full size servo? | NoDecoDiver | Losi Mini-Rock Crawler | 17 | 12-25-2008 11:31 PM |
High Power BEC/Servo Power Supply | MANTIS | Electronics | 14 | 08-09-2006 03:33 PM |
