01-11-2012, 04:07 AM | #1 |
Quarry Creeper Join Date: Nov 2010 Location: right here!
| CC sv2 wont power brushless but works on brushed motor
I acquired this SV2 from a member here and its brand new. My problem is im tyring to power a velineon motor but it seems to not work. I plugged in a brushed motor and it works fine but when it comes to the brushless traxxas velineon it wont spin the motor at all. I tried 2 different velineon motors and had the same results. What can be wrong?
01-11-2012, 04:17 AM | #2 |
Pebble Pounder Join Date: Feb 2011 Location: Northwich, England
| Re: CC sv2 wont power brushless but works on brushed motor
Not 100% sure, but I believe you will need to use a castle link to set it to brushless mode rather than brushed mode. Hth Pete. |
01-11-2012, 05:07 AM | #3 |
Quarry Creeper Join Date: Feb 2010 Location: Knee deep in a creek with a fish on the line
there is a way to do it without the castle link, you just need to follow the steps in the book and count all the flashing lights. I can tell you it is way less hassle with the castle link.
01-11-2012, 06:39 AM | #4 |
Tanks for the help guys. ill give it a shot BUT as of right now I cant find the daymm manual. I misplaced it and the supid thing is I was just holding it couple of minutes ago.
01-11-2012, 06:46 AM | #5 |
The manual is here if you can't find yours. :- http://www.castlecreations.com/suppo...s_ed_guide.pdf Pete. |
01-11-2012, 06:47 AM | #6 |
I think if you go to castle creations they have the manuals online. Of course after you do that you will find the manual as you walk back out to the garage, just a little trick I learned years ago.......your welcome |
01-11-2012, 07:07 AM | #7 |
This is complicating!!1 I did the calibrating part but after that im lost. I cant go into the menu where you can start programming manually.
01-11-2012, 07:24 AM | #8 |
RCC Addict Join Date: Aug 2011 Location: Pipersville
If you have the extra $20 buy the castle link. It will save you time and frustration. You can use it to set up everything you might dream of on that esc. Hope you get it working. |
01-11-2012, 08:13 AM | #9 |
| Re: CC sv2 wont power brushless but works on brushed motor X2 it gives you way more options for your drag break, and you can adjust your throttle/break curves to you liking.
01-11-2012, 10:24 AM | #10 | |
| Re: CC sv2 wont power brushless but works on brushed motor Quote:
Slow down, read the manual, read the manual again like you really want to learn, then go try stuff. | |
CC sv2 wont power brushless but works on brushed motor - Similar Threads | ||||
sidewinder micro wont run brushed motor | stanmondz | Electronics | 4 | 12-05-2011 08:58 PM |
Any way to compare power from a brushed to a brushless? | Iberian | Team Losi Comp Crawler | 4 | 12-29-2009 12:50 PM |
What motor to use? brushed or brushless | slashbasher | Electronics | 4 | 11-24-2009 11:24 AM |
