Thread: Swapped out ESCs
Old 01-11-2012, 05:40 PM   #1
On the lookout for Rocks
constantmotion's Avatar
Default Swapped out ESCs
I just swapped out a Mamba Max for a HH BR-XL on a HH 30T motor. The motor is not chiming. I hooked up a silver can and it works just fine. Hooked up the Mamba Max back up...no chime. WTH.....nothing else has changed. I see lights on both ESCs and it's responding to my throttle inputs (lights changing on ESC). Any ideas?
constantmotion is offline   Reply With Quote
Old 01-11-2012, 06:06 PM   #2
Default Re: Swapped out ESCs
I would guess you may have to calibrate the New HH BRXL to your reciever. Then try it and see what happens.
AsILayDying is offline   Reply With Quote
Old 01-11-2012, 06:14 PM   #3
I have calibrated the ESC to the Tx. ESC not at fault b/c it works fine with another motor. Something to do with the motor. All solder connections are good.
Old 01-11-2012, 06:15 PM   #4
I'm having the same issue. I hooked it all up. ran for a few minutes until I snapped may stock drive shaft. Got some MIPs and now I get what OP describes. tried to re-calibrate and still nothing. Hooked up the castle link, reset to default, still nothing. Any more info would be helpful to me as well.
profsrkos2012 is offline   Reply With Quote
Old 01-11-2012, 06:30 PM   #5
Nobody
Cordwood's Avatar
Does the motor turn if you put power directly to it?
Cordwood is offline   Reply With Quote
Old 01-11-2012, 06:34 PM   #6
I just hooked up a battery (AA) to the motor and I have nothing. Motor isn't locked up...still spins freely.
Update:
It working just fine now. Forgot that I did mess with one of the brushes...might not have been fully seated.
Old 01-11-2012, 06:38 PM   #7
Hooked to any other esc, my motors work.
Old 01-11-2012, 06:46 PM   #8
Default Re: Swapped out ESC's
Wow, busy night....
-If a motor does not work in a rig, BUT does work with a direct connect to a battery, the issue is the ESC.
-If a motor does not work in a rig, AND it does not work with a direct connect to a battery, the issue is the motor.
ESC can be ESC to RX calibration, ESC settings (like the ESC LVC), bad ESC, bad battery
Motor can be a dead motor, or a loose brush connection, hung brush (provided the motor spins freely by hand).
Charlie-III is offline   Reply With Quote
Old 01-12-2012, 01:13 AM   #9
Problems solved. Dead bands were set way low. Working like a champion.
Swapped out ESCs - Similar Threads
Swapped the chassis on my RF!! :) Madpete98 Kyosho Crawlers 9 03-10-2009 09:08 AM
Body swapped rckjeep 2.2 Scale Rigs 15 10-10-2007 10:16 AM
WK swapped ends, it's easy MikeSSS HPI Wheely King 4 05-10-2007 10:34 PM
All These ESCs !! pc6uru Electronics 6 05-05-2007 06:18 PM
Swapped in real electronics... 350jeepcj5 General Crawlers 9 04-22-2006 11:41 PM
