01-11-2012, 09:18 PM | #1 |
Quarry Creeper Join Date: Jan 2011 Location: Kingston NH
| axial led's
hey guys i have the simple led system from axial but it only came with two plugs driving lights and brake lights i have head lights and parking lights i want to hook up as well can i tap in to the wires for the other lights or will i over load the circuit. whats the best way to go about this
01-12-2012, 07:01 AM | #2 |
| Re: axial led's
You can but you will need to tap in before the resistor to the existing LED and put a resistor in line with the new LED to bring the voltage down as not to burn out the bulb. I believe that all the resistors (circuit board) are in the shrink wrap so you would need to tap into the power between that board and the receiver, you are making parallel connections so you won't mess up the existing ones. Xtreme RC Dec 11 had a very good write up on how to make a low budget LED system which you can adapt to the Axial simple. Last edited by AreCee; 01-13-2012 at 08:26 AM. |
01-12-2012, 08:37 AM | #3 |
| Re: axial led's
You will definitely overload the circuit and none of the LEDs will light up if you tap in along the string after the resistor as AreCee said. I am no expert on LEDs but I've had several pop in my face to learn the hard way lol. I rigged up several frankenstein setups usually running off a 12V camera battery and I buy all my stuff from RadioShack. You can check out rclighthouse.com to see some configurations.
01-12-2012, 05:38 PM | #4 |
| Re: axial led's |
01-13-2012, 11:51 PM | #5 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
| Re: axial led's
How would someone wire the brake lights to be functional?
01-14-2012, 12:15 AM | #6 |
Quarry Creeper Join Date: May 2006 Location: san diego
| Re: axial led's
should check out the eflight led's they have 4 leads coming off the board and then you can add y-harrness and extentions to get the job done.
01-14-2012, 07:57 AM | #7 |
| Re: axial led's This might be an option for you: Brake, Reverse and Driving Light controller $30 |
01-15-2012, 08:58 PM | #8 | |
Rock Stacker Join Date: Dec 2010 Location: Orangevale
| Re: axial led's Quote:
So if you are nuetral on the throttle the headlights are off? I am interested in these but would like to keep the headlights on when stopped. Is this possible? | |
01-15-2012, 09:16 PM | #9 | |
I just figured that if there were headlights, that they would get plugged into a Y cable or into the Bat connector of the receiver. No problem adding that place to plug in though! | |
01-16-2012, 06:01 AM | #10 | |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
axial led's - Similar Threads | ||||
Finally MY LED's ARE WORKING!!! over 26 LED's | 4x4Crawler4LIFE | Scale Videos! | 11 | 07-28-2009 09:07 PM |
Led's | cammok5 | Chit Chat | 3 | 10-31-2007 09:28 PM |
LED's | Mikekx65 | General Crawlers | 6 | 09-30-2007 12:06 AM |
LED's... | Cslax06 | Electronics | 2 | 08-26-2007 09:49 AM |
