01-12-2012, 12:11 PM | #1 |
Rock Crawler Join Date: Dec 2011 Location: Northwestern PA
| Best servo for $100?
Being a believer in "you get what you pay for", what is the best crawling servo for an AX-10 for no more than $100? Thanks I'm still running the stock one. |
01-12-2012, 12:36 PM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: Wheeling
| Re: Best servo for $100?
Hitec 7954SH and run the bastard @ 9v!
01-12-2012, 12:45 PM | #3 |
You can usually get a used Hitec 7955TG for under $100 shipped...that's 333oz/in @ 6.0V. Or a new Hobbico CS170 servo same specs $90 new not including shipping.
01-12-2012, 12:49 PM | #4 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
USED. I just picked up a used Futaba S9157 for $75. Classifieds are your best friend my man.. |
01-12-2012, 12:57 PM | #5 |
RCC Addict Join Date: Jan 2007 Location: Bouldertown
The hitec 7954 is the best servo for 140 dollars! And it only costs 80 dollars. High voltage and over 400 oz on just 6v. There is no other choice n my book. |
01-12-2012, 01:10 PM | #6 |
Thanks guys, this is great info and great options.
01-12-2012, 01:11 PM | #7 |
Quarry Creeper Join Date: Jun 2010 Location: Ireland
+1 7954sh ftw |
01-12-2012, 01:56 PM | #8 |
CS170.... TowerHobbies.com | HCAM0316 Hobbico CS-170 Std Digital Ultra Torq 2BB TG Servo U 7955.... TowerHobbies.com | 37955S Hitec HS-7955TG Digital HT Titanium Gear Coreless Servo 7954.... TowerHobbies.com | 37954S Hitec HS-7954SH High Voltage Ultra Torque Dual BB Servo 7950.... TowerHobbies.com | 37950S Hitec HS-7950TH HV Digital Ultra Torque Coreless TG S9157.... TowerHobbies.com | S9157 Futaba S9157 Digital High-Torque Servo I use a 7950 @ 7.4 volts in my 2.2 Bully MOA. There is a shop local to me (that is also on Ebay) that I can get one picked up for ~$120 out the door. I don't think running any of these long term @ 9vdc would be good. |
01-12-2012, 02:15 PM | #9 |
A question: Is there an advantage to running a High Voltage servo, as opposed to a regular voltage servo? Is anything additional required to run a high voltage servo? My rig has the stock AX-10 electronics, a CC BEC, and 7.4v / 2s LiPo battery. Thanks! |
01-12-2012, 02:18 PM | #10 |
the 7954SH will serve well at 9V. you wont stress it that's for sure. as long as you're not running courses back to back to back it gets warm but not hot enough to the touch. i have one in my sportsman and my Xr, both running XR steering over 55*.
01-12-2012, 02:21 PM | #11 | |
| Re: Best servo for $100? Quote:
even throwing nominal battery voltage on 2S to a servo will make you tingle in the naughty bits. at 9v, its really beefcake. | |
01-12-2012, 02:28 PM | #12 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
7954 is a good choice 403oz at 7.4v. No idea what benefit you would get from over volting it unless you like buying new servos. The 7950th is a good choice too. 486oz at 7.4v for $114. https://www.troybuiltmodels.com/items/HS7950TH.html |
01-12-2012, 02:50 PM | #13 |
Got it - that makes sense. * duh *
01-12-2012, 03:13 PM | #14 | |
01-12-2012, 03:15 PM | #15 |
Never mind, I found it. They all do I guess.
01-12-2012, 07:50 PM | #16 | |
The biggest downside to this is that servo power drops off as the battery voltage drops. | |
01-13-2012, 11:01 AM | #17 |
Gotcha, thanks!
01-13-2012, 12:30 PM | #18 |
Rock Crawler Join Date: Nov 2011 Location: Paradise, ca
i have a jr racing z9100t in my creeper thats all metal gear high torque servo and the same specs as the hitec should be 100 to 140 depending on where you find it
01-14-2012, 12:37 AM | #19 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
just bought a hitec HS 7955TG servo for 119.99 plus tax came out to 134.00.. my friends have the same servo and have ours plugged into the receiver and we're not running a BEC and havent had any problems. we are running 2s 800-850mah lipo's.
Best servo for $100? - Similar Threads | ||||
Crawler Innovations Servo Guard - Servo Clamp - Servo Mount GIVEAWAY!!! | Nova's Ark | General Crawlers | 219 | 10-18-2010 12:43 PM |
Whose quote is give 100 people a chassis and they'll build it 100 diff ways? | Rig Rocker | Chit Chat | 6 | 10-05-2010 10:40 AM |
looking for good servo under 100$ | Axialfan19 | Electronics | 20 | 09-10-2010 09:48 PM |
