E.s.c troubles I recently baught a used Traxxas Summit and tried to put my B/L system into it but every time I turn it off the esc seems to loose it,s memory and is unresponsive . I ran into this when I first tried putting the system into my E Savage but for some reason it worked everytime after I matched iit to my radio. For somereason I cant get it to match up with my radio and stay matched or linked .The BL motor is a 2075 kvwith aHobbyKing 100A ESC with fan cool. So I baught a factory 775 motor for it and it works great except for the slop in the Tranny but aparently that's normal for these 1/10 trucks. |
Re: E.s.c troubles There are a couple "Hobbyking" ESCs, but I'm betting this is the ESC you have. HobbyKing R/C Hobby Store : Hobby King Brushless Car ESC 100A w/ Reverse (Upgrade version) If it is your's, then its made by Aeolian and is the Quik 100a Aeolian 100A Brushless Motor ESC for RC Auto car Free Ship | eBay has some programming info on it that might help. |
Re: E.s.c troubles Yes that is it . The only problem with it now is the program switch is nfg and broken off so I have to use a paper clip to make the actual conection between the two contacts but it dose still work. |
