01-16-2012, 10:12 AM | #1 |
Newbie Join Date: Dec 2011 Location: Los Alamos
| Steering servo for LNC
Hi I want to upgrade the stock servo with a HITEC servo HS-7955TG that needs 6v. Can I do this with the stock ESC that has a BEC that can handle 5v, 1 amp max at 7.2v? If that HITEC servo does not with the stock LNC ESC is there one you would recommend? I want more steering torque but do not want to upgrade the ESC yet. thanks |
01-16-2012, 10:46 AM | #2 |
| Re: Steering servo for LNC
Unless you run: -Holmes Hobbies BR-XL or -External BEC (CC 10A is fine, no need for a CC Pro BEC) You will likely have issues with ANY servo over ~200inoz. When you load up the servo, it will "brownout" the RX power and everything will stop. If you run 2S, you "may" get away with direct power wires from the ESC input direct to the servo, but the servo needs to be able to handle ~7.4volts. |
01-16-2012, 08:56 PM | #3 |
Thanks for the information. One question though you mention adding an external BEC but my LNC stork ESC has a built in BEC. So I cannot add another one correct?
01-16-2012, 09:08 PM | #4 |
Pebble Pounder Join Date: Dec 2011 Location: Ridgecrest, CA
I am running that Hitec servo thru the stock Losi ESC with no issues at all. Jerry
01-16-2012, 09:17 PM | #5 | |
| Re: Steering servo for LNC Quote:
If you run the external BEC through the RX, you need to remove (not cut) the red wire from the ESC to the RX. Just tape it up so it won't short on anything. Just about all ESC's today have an internal BEC. | |
01-16-2012, 09:29 PM | #6 |
Jerry just to be clear you using the HITEC servo HS-7955TG with the stock LNC ESC and 2S battery with no issues with significant torque from that servo? thanks for your information...
01-16-2012, 09:34 PM | #7 |
Thanks I'm new to the changes in this hobby after being away from it for 20yrs! Ok how do I run an external BEC directly to the stock servo by passing my ESC with built in BEC? thank you for your patients ....much appreciated! I want to get this right so I don't fry any of the electronics.
01-16-2012, 09:47 PM | #8 | |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
CreationFab - Plugs Other Receiver Bypass Adapter Also a search of "bec install" on this forum will help you out as lot as it is the most common question I see asked daily. I think there is even a stickie or 2 on the subject. Also the 7955 will not run successfully off the stock esc. You wont see anywhere near the power it can produce and will most likely as Charlie pointed out give you brown outs. | |
01-16-2012, 09:59 PM | #9 |
| Re: Steering servo for LNC I am using the HS-7955TG with the stock LNC ESC on 2S, turning Comp Claw tires. Servo stall has not been an issue except in extreme bind situations, and I have never suffered the brownout problem that many talk about. Jerry
01-16-2012, 11:12 PM | #10 |
| Re: Steering servo for LNC And how much of your $100+ servos torque are you wasting by not running a $20 bec? You bought a race car and are filling it with crappy pump gas. The extra loads you are putting through your esc are slowly killing it and decreasing its life expectancy also. You might think you have good steering power but try a bec and you will be blown away at what you have been missing out of your servo |
01-17-2012, 06:28 AM | #11 | |
Torque: 249.96 oz-in (18 kg-cm) at 4.8V 333.29 oz-in (24.0kg-cm) at 6.0V | |
01-17-2012, 07:12 AM | #12 |
Thanks all for the information! Also to the link to a Receiver Bypass Adapter. I have enough information now to install a 20 amp CC BEC and the reasons for doing it for a powerful steering servo. thanks all for responding so quickly..... |
01-17-2012, 08:29 AM | #13 | |
When you are done, post back with impressions, please. | |
Steering servo for LNC - Similar Threads | ||||
battery/servo tray for lnc | RJM95 | Team Losi Comp Crawler | 6 | 05-16-2011 02:22 PM |
steering on lnc/lcc | chrispy76 | Team Losi Comp Crawler | 18 | 05-16-2010 05:21 PM |
servo torque on lnc | losikid | Team Losi Comp Crawler | 10 | 11-26-2009 11:14 PM |
