01-16-2012, 06:13 PM | #1 |
| Electronics issues
Alright. i'm stumped. So when my crawler takes a hard a fall it becomes un responsive, BUT all i have todo is unplug then plug the battery in and its good to go. Any idea's...all the connections seems good, I can wiggle everything and nothing happens. I've tried two different rx's. My servo is wired directly to my lipo, then my tekin rs powers my rx and micro dig servo. (running a lcc/overkillrc hybrid shafty) |
01-16-2012, 06:26 PM | #2 |
Rock Crawler Join Date: Oct 2011 Location: smithville
| Re: Electronics issues
Could it be that maybe it comes unplugged a little?
01-16-2012, 06:30 PM | #3 |
Newbie Join Date: Dec 2011 Location: Galatia
Is it possible the battery pack itself and not your electroniics? Is there a possibility of a bad or loose connection between cells that gets jarred in a hard crash? Or maybe the leads to the battery pack? sounds like there may be the possiblity of a (partial) nreak in a wire. I always start at the batteries when anything electric or electronic gives me fits. Wow thought here, does anyone even assemble their own battery packs anymore with the advent of LiPO technology?
01-16-2012, 06:42 PM | #4 |
Rock Stacker Join Date: Aug 2011 Location: Canada
Are you by any chance running a failsafe on your rig? I used to get a similar effect when running a Venom failsafe in my old Savage 21. After a big jump, it would cut the throttle back until I turned off the electronics and then back on. |
01-16-2012, 07:22 PM | #5 | |
| Re: Electronics issues It has power when i plug/unplug...and power doesn't cycle on/off or i should just have a short delay till the tx/rx re binds Quote:
Kinda, i'm running a hard lipo cutoff. But it may be it, i'll start paying attention to whether if my tires are spinning or not when i land. I wonder how much current that draws by loading up my motor like that. | |
01-16-2012, 07:55 PM | #6 |
Wow, good issue...... OK, issue happens with: different packs different RX's I'm assuming it's a hacked GT3B? When you say, "unresponsive", are the ESC &/or RX LED's still on? Does steering (or anything else) still work? What ESC? Are you sure you're not just awestruck on the amazing stuff your rig just did?? |
01-16-2012, 09:07 PM | #7 | |
| Re: Electronics issues Quote:
By unresponsive i mean it has power, just it doesn't listen to the tx. Actually, i guess i need to see if the rx has power when this happens, as its powered by the esc's bec. But what would cause the esc to stop sending power? I think it maybe the lipo cutoff as mention before. Because it is a hard cutoff, a voltage spike may set it off. Tekin RS is the esc, running a 13.5t sensored tekin redline It hasn't just happened once, it'd done it quite a few times. But i am awestruck as to why, its abit strange. | |
01-16-2012, 09:13 PM | #8 |
Almost sounds like a bad connection from the ESC BEC to the RX, then you're waiting for the RX to restart. Maybe a bad connection to the ESC (or bad internal connection) making it wait until it restarts. Does the ESC normally chime @ start-up? If so, do you hear that when this happens? If not, while it may be a LVC issue, I would look to the ESC BEC to RX connection "may" be a bit loose (although you stated you wiggled connections). |
01-16-2012, 09:20 PM | #9 |
What's the C rating on those packs? That's a hot motor, I wouldn't expect good life from any pack that can't pass 50a cont, 100a peak. You don't ever have this issue in binds or full throttle burst?
01-16-2012, 09:28 PM | #10 | |
No, i don't have any issues on full out binds. But i do know that if i stall out that motor too many times in a hole that it'll make my lipo pack puff up like ballon and scare the livin poo out of me. So far i've super puffed 1 pack and kinda puffed another. and on hard running the pack will be toasty hot once its dead....I can get about 10 minutes out of the pack with normal crawling. When its in torquey spots it lasts about 6 min. Here soon i'll be upgrading to holmes 3s packs (running 2s right now) I hope the extra voltage will help lower my draw. | |
01-16-2012, 09:31 PM | #11 | |
Yes, the rs does a chime at startup. But i don't think i hear it after i loose my control over it. Next time it happens i'll check and make sure i have rx voltage and un bury my esc and see what error's its giving me. | |
01-16-2012, 09:47 PM | #12 | |
Just curious to see what it turns out to be. | |
01-16-2012, 09:49 PM | #13 |
Quarry Creeper Join Date: Nov 2006 Location: out in boonies!!
Maybe something in esc causes it to short out on hard crash....got another esc to try?
01-16-2012, 10:00 PM | #14 |
I'd be looking for a lot higher C packs. I'm not sure if tekins LVC is as adjustable as castle's, but setting to 3.5 per cell will help about puffing packs. That said I'm not sure if this is a LVC issue or a brownout issue from the front tires smacking hard without a BEC. Or are you running you servo 2s direct?
01-16-2012, 10:15 PM | #15 |
Austin, maybe try this if you get a chance: Get a good size capacitor, maybe 2000uF or so and solder it to a servo plug. Plug it in your receiver. This will make sure that your receiver doesn't suffer from a brownout after a hard fall. I'm not saying this will work for sure, but it might be worth a try. |
01-16-2012, 10:29 PM | #16 | |||
My servo is running 2s direct. Quote:
01-17-2012, 05:58 AM | #17 |
While those HH packs are quality packs, their still simply not enough. You need 45c or higher unless you increase mah also and that's not ideal for a comp truck. Check out the Hyperion 1100's in there strongest cells.
01-17-2012, 05:59 PM | #18 | |
And i'd much rather give my money to a us company than a chinese when buying quality packs. And my #1 picks will be either a HH pack or a Elite pack. Both with a true 35c rating which is alot higher than what i'm running now. As long as i don't stay bound in a hole for an entire pack my gens ace handle the motor just fine. Now back to the issue at hand, more i think about it, it most likely is a brown out issue because the esc has a a very weak bec and it seems like usually my dig servo is engaged. So maybe the internal bec just can't power my mega torque micro servo when the motor takes a hit and spike an insane amount of current. It'll be afew days before i get more time to tinker with my losi, so i'm stuck to thinking till then | |
01-19-2012, 12:06 PM | #19 |
Newbie Join Date: Aug 2010 Location: San Antonio
I ran into a similar problem when running multiple servos. I redid all of my connectors and installed a BEC, problem solved!! Good luck!!!!!!!!!!!!!!!!
01-19-2012, 02:38 PM | #20 |
I have a similar issue on my stadium trucks upon hard landings, although itīs just the steering that become unresponsive for a few seconds and then back to normal( running sidewinder esc btw), it will do it almost every jump, depending on how hard, this is with just a standard servo, i can only imagine that a much higher torque servo would definetly send the esc into shut down mode plus the extra draw from the dig servo.
Electronics issues - Similar Threads | ||||
BND Night crawler electronics issues | du4x4 | Electronics | 20 | 04-08-2011 12:41 PM |
Stock Electronics issues | KingJerd | Axial SCX-10 | 10 | 11-30-2010 05:11 PM |
issues with stock electronics | PineapplAssasin | Axial AX-10 Scorpion | 10 | 06-20-2010 12:09 PM |
lcc electronics glitching issues... | Fluxnutz | Team Losi Comp Crawler | 13 | 12-30-2009 10:25 PM |
Help, new TTR Tremor but I am having issues....Electronics?? | ScaleHobbies | Tamiya Clod Buster | 0 | 02-22-2005 05:18 AM |
