01-20-2012, 04:44 PM | #1 |
Rock Stacker Join Date: Dec 2010 Location: Oviedo
| batttery problem can it be fixed?
my 3cell lipo read full charge in 2 cells but in the 3rd it gave me 0.0v. i tried charging it and it stops charging at 3.74v and 4.20 in the rest, is there any way to fix this or is the battery trash?? |
01-20-2012, 04:58 PM | #2 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
| Re: batttery problem can it be fixed?
I made an adapter for charging individual cells through the ballance tap, its an "at your own risk" operation but one of my batterys was doing what yours was doing, I plugged my adapter into the low cell and charged at a really low rate on 1s and brought it up to full, ever since then it's been working as it should. pics in a sec of what I did.
01-20-2012, 05:04 PM | #3 |
now, please do this only if you are confident and prepared for anything, as there is usualy a reason a cell wont take a full charge, outside or in the garage would be an excelent idea, and plan to be there the whole time its charging incase SHTF. I store this lipo on its own in a lipo bag now. but like I said, works as it should now. I made my adapter out of a JST plug, I just cut the square box that protects the prongs off. (exacto cut it off just fine, no saws needed) and then check the cells and find the low one and plug it in (MAKE SURE POLARITY IS CORRECT) set your charger to charge 1s lipos (I charged at half an amp) (yes, thats a hobbyking "B-Grade" lipo and this was to be expected, but so far so good, got 3 of them they are awesome) if you're going to throw it out send it to me haha. Last edited by fred0000; 01-20-2012 at 05:09 PM. |
01-20-2012, 05:22 PM | #4 |
ill give that a try but just one question so i dont blowshitup how do i check polarity?
01-20-2012, 05:23 PM | #5 | |
| Re: batttery problem can it be fixed? Quote:
or you can look up how a balance plug is wired and you'll see what is + and what is - for each cell, but you're going to need a volt meter to locate the cell anyway. (based on your responce this is something you should NOT try, seems your in over your head already, just being honest here) just want to add.. again, I am not responsible if you try this and SHTF. Last edited by fred0000; 01-20-2012 at 05:26 PM. | |
01-20-2012, 05:34 PM | #6 |
i just know how dangerous lipos can be and i just wanted to double check and plus best way to learn is by doin it haha thanks for the help and i dont have a fan so im not worried about SHTF |
01-20-2012, 05:36 PM | #7 |
you will want to look up how a ballance plug is wired anyway. black is NOT a common ground like many people think. if you do this be sure to let us know how it goes, but do it knowing how dangerous it can be, don't short the lipo with the volt meter prongs, good luck here's a diagram, there are better ones out there too. (for a 4s but you should get the idea) Last edited by fred0000; 01-20-2012 at 05:40 PM. |
01-20-2012, 05:46 PM | #8 |
my yellow and blue, so my second cell and the blue is + and yellow is - so thanks for the help now its just gettin that cell out and replacing it if i cant bring it to full charge with the prong idea, thanks ill keep u posted
01-20-2012, 05:54 PM | #9 |
battery check... low voltage it wont even let it charge, so does that mean i have to replace that cell or am i missin something? i have the battery pluged into the balancing ports that are for the low cell and in the correct +- oreintation, charger set at .1a and 1s and it wont charge, is that all corect? |
01-20-2012, 05:57 PM | #10 | |
like this (if you could take a picture of your setup it could be helpfull) Last edited by fred0000; 01-20-2012 at 06:02 PM. | |
01-20-2012, 06:05 PM | #11 |
exactly like u have the only difference is the volt meter is reading 1.12v and falling it was 3.74 and now it is the 1.12v so i think that means shit is toast and the cell has to be replaced
01-20-2012, 06:08 PM | #12 | |
this is highly un-recomended by many members, I however would try it myself. I would do this outside away from any flamables. Dead Lipo Battery Recovery - YouTube in the end, how much was the lipo, and how much time/risk are you willing to put into it. keep us up to date regardless if you choose to try and save it. Last edited by fred0000; 01-20-2012 at 06:15 PM. | |
01-20-2012, 06:22 PM | #13 |
doesnt seem to hard imma gonna try it so ill be back in a few if it takes a charge or not, and it is a traxxas 1400mah 3s 26 bucks but i wanna learn so i can save it if it happens to another battery
01-20-2012, 06:32 PM | #14 |
so far so good, it is balancing now!! |
01-20-2012, 07:15 PM | #15 |
| Re: batttery problem can it be fixed? |
01-20-2012, 07:18 PM | #16 |
nope its still good and charging so i must say thank you for comin to the rescue, haha i owe u haha hopefully i dont have issues with it now but better than havin to buy a new one haha
01-20-2012, 07:20 PM | #17 |
once its fully charged up again check the voltage on all cells and just keep an eye on it over the next few cycles, maybe you'll luck out like I did and it'll work as normal again.
01-20-2012, 07:24 PM | #18 |
i hope
01-20-2012, 07:24 PM | #19 |
Rock Stacker Join Date: Mar 2011 Location: oconee
lipo batteries are amazing and dangerous as hell all at the same time.
01-20-2012, 08:32 PM | #20 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
fred you use the regular + - from charger that charge the batt in the bal port of the plug for what cell is lower then the others........bob .... |
batttery problem can it be fixed? - Similar Threads | ||||
can this be fixed ? | rock-gobbler 77 | Electronics | 4 | 05-13-2011 03:00 AM |
Batttery mounting | jordi555 | Electronics | 3 | 04-17-2009 04:53 PM |
Fixed our bee problem.........I think.. | west virginia krawler | Chit Chat | 9 | 08-26-2007 11:25 AM |
TQ3 and Tmaxx problem **FIXED** | GeoffSFAs10 | Electronics | 8 | 12-27-2004 02:42 PM |
