01-21-2012, 12:04 AM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: 419 area
| esc question?
this probably a dumb question.....if an esc has a 35 turn motor limit would it work for a 100 turn motor??
01-21-2012, 12:13 AM | #2 |
| Re: esc question?
Yes, it will work. Just curious, what are you running a 100T motor in? |
01-21-2012, 07:23 AM | #3 |
Rock Stacker Join Date: Dec 2009 Location: New Hampshire
| Re: esc question?
just to let you know the motor limit on the esc means it cant't handle anything under the limit it says. anything above is fine
01-21-2012, 08:21 AM | #4 |
| Re: esc question?
im running it in a redcat rockslide 1/8 scale crawler. Thanks guys for the help. i just wanted to make sure before i spend over $100 for a pair of esc's and then they not work for it |
01-23-2012, 11:41 AM | #5 |
Quarry Creeper Join Date: Feb 2008 Location: US
| Re: esc question?
With motors, the lower turn windings, the more amps the motor will draw to produce the same amount of torque. So a 35T motor will draw way more amps (and put more stress on your electronics) than a 55T or even a 100T would in the same bind or climbing the same obstacle. This example assumes that you have the same number of poles in the motors. |
esc question? - Similar Threads | ||||
ESC Question | tolowbro | Electronics | 0 | 02-22-2011 02:08 PM |
ESC question | martinez34 | Electronics | 8 | 02-21-2011 02:46 PM |
ESC question | sweetride4me | Electronics | 5 | 03-02-2009 07:42 PM |
esc question | snowball50 | Electronics | 7 | 01-29-2007 03:57 PM |
