01-22-2012, 05:57 PM | #1 |
Newbie Join Date: Jan 2012 Location: roswell
| ax10 glitching issue....help?
hey guys, my ax10 is glitching real bad when my truck gets maybe 15 feet from me...i switched out the radio and receiver, but that did not salve the problem....right now im using a 27t motor, mamba max escc, and stock radio and receiver....any advise would be great, thank you!
01-22-2012, 06:08 PM | #2 |
| Re: ax10 glitching issue....help?
What battery in the rig (NiCD/NiMH, LiPO & how many cells or pack voltage)? Did you try a different battery pack? Are the batteries in the TX good? Are there caps on the motor? Did this just start happening or has it started after a change (like different ESC or motor)? |
01-22-2012, 06:13 PM | #3 |
im using 11.1v 3s lipos. i tried 3 different batteries. brand new batteries in tx. im pretty sure it started when i put the 27t i. i had a 55t in before and it wasnt nearly as bad
01-22-2012, 06:24 PM | #4 |
also no i do not believe there are caps on the motor
01-22-2012, 07:34 PM | #5 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
no caps on a worn motor will cause major glitching, least from my experience. Change out the motor and try it....or install some caps and give it a go...is the radio am, fm, or 2.4??
01-22-2012, 08:00 PM | #6 |
Come and take them!® Join Date: Oct 2011 Location: Rolling Hill's of Maryland™
Make sure Rx antenna wire is clear of any other wires and your Rx is not bunched up with any wires around it. This is common when cramming stuff into radio box.
01-22-2012, 10:20 PM | #7 |
squatch71,i changed out the motor and that seems to have fixed the problem. can i install caps on an axial 27t? and right now im using the stock am radio (but my next purchase is a 2.4) hunter711, my servo wire and my esc wire were packed right on top of the receiver, but the rx wire is bound in a plastic wire holder and servo taped to the roof of my tuber. would the wires cause the glitching? |
01-23-2012, 10:17 AM | #8 |
I have had it happen. Sometimes I drill small hole in Rx box lid above Rx and route antenna out that way, when things get too conjested in box, applying small amount of sealent in hole around antenna wire, just to keep moisture out. See: Wraith Picture Archive, Last Page, Post #264, 3rd picture Last edited by Hunter711; 01-23-2012 at 10:27 AM. |
01-23-2012, 06:26 PM | #9 |
Awesome, thank u for the advice
ax10 glitching issue....help? - Similar Threads | ||||
Glitching issue... Help | WLKNTALL | Electronics | 9 | 09-16-2021 07:19 PM |
my ax10 is glitching...any ideas? | mummyman | Axial AX-10 Scorpion | 17 | 01-23-2012 06:29 PM |
Glitching issue!!!!!!! | WLKNTALL | Axial AX-10 Scorpion | 4 | 04-11-2009 07:57 PM |
Glitching Issue, Sidewinder, 11.1 Lipo | mikedoug | Electronics | 13 | 10-15-2008 10:45 AM |
glitching issue, any ideas | jevyguy | Electronics | 8 | 11-09-2007 08:41 AM |
