01-22-2012, 08:25 PM | #1 |
Rock Stacker Join Date: Nov 2009 Location: southern ok
| brushed motor in water?
Everywhere i have searched says that brushed motors can be ran in water without any problem. I just finished waterproofing my scx 10 and took it out for a test, everything worked fine until the motor goes under water then it "glitching" trying to go back and forth on its own with me not able to control it. I'm assuming it is arcing across inside the motor. I am running 11.1 lipo. What can I do to fix this so it doesn't give me problems when the motor becomes submerged?
01-22-2012, 08:31 PM | #2 |
| Re: brushed motor in water?
Sounds more like an ESC or RX issue, motor will either do what the ESC tells it, or stop.....NOT glitch back & forth. |
01-22-2012, 08:36 PM | #3 | |
Rock Crawler Join Date: Jul 2008 Location: River Falls
| Re: brushed motor in water? Quote:
I can run my brushed motors completely submerged with no issues.. Last edited by the_ghetto_rig; 01-22-2012 at 08:39 PM. | |
01-22-2012, 08:36 PM | #4 |
Quarry Creeper Join Date: Sep 2007 Location: strawtown
been running brushed motors since the 80s never had a problem with the motor getting wet. did you get the rx waterproofed good |
01-22-2012, 09:08 PM | #5 |
Pebble Pounder Join Date: Feb 2010 Location: Calgary
My bet is a wet rx. I ran my rustler through a deep puddle once and a similar thing happened. I dried it out and it's been fine since. It was a SR3100 fwiw.
01-22-2012, 09:20 PM | #6 |
N.E.R.C.C Uncle Blinky Join Date: Dec 2008 Location: RUKDNME...
toss the rx in a balloon and send it |
01-23-2012, 06:55 AM | #7 |
I plastidipped everything. I can dunk the rig while holding only the motor in the water and that is when it starts acting up. As soon as I pull the motor out of the water it stops. The rx and esc are not even in the water. Everything acts completely normal as soon as the motor is out of the water.
01-23-2012, 07:22 AM | #8 |
Rock Crawler Join Date: Jun 2009 Location: summertown
What kind of motor? The closed can Axials, HPI, Traxxas, etc... Can be run underwater with minimal wear. A rebuildable can doesn't need to be run under water under torque(in a rig) most of the springs are fairly strong and just Burn the brushes and comm. I have set them up so they will run with minimal wear but it's not really worth the loss in power and speed. TapaTalk on Iphone4 |
01-23-2012, 08:42 AM | #9 |
Newbie Join Date: Dec 2011 Location: USA
We use to break new brushes in, in a jar of water back in the day so you should be fine
01-23-2012, 08:57 AM | #10 | |
AM & FM are very pissy with this, but it can affect 2.4ghz as well. Does your motor have caps on it? | |
01-23-2012, 09:02 AM | #11 |
If your radio is 2.2G, is the tip of antennae above water? My Spektrum will work fine in the water until the antennae goes under. |
01-23-2012, 10:13 AM | #12 |
Yes you can break a motor in under water using about 3V's, I do it to. But if you put a rebuildable can motor under water in a truck under power your just askin for trouble. Does the RX light go off or blink for just a second when this happens? Last edited by Twisted Nuts; 01-23-2012 at 10:17 AM. |
01-23-2012, 12:40 PM | #13 |
I just have a backup motor in it right now. It's a RC4WD 55t and yes I'm using 2.2 radio. I will have an update after work. I did find a couple wires going from the esc to the rx that had a cut on them. Maybe they were arcing across to each other. I liquid taped them and will test it when I get home. Not sure about the caps on the motor.. The antenna never went under water.
01-23-2012, 08:35 PM | #14 |
well the fixed wires didn't help so I tore into it more. After really looking everything over I found a small crack in the end of the bec where I had sealed it. When this all started it was acting like it only had half power. Now the esc will not bind with the rx. If the bec is shorted out will it cause this to not bind?
02-01-2012, 10:16 AM | #15 |
Well when I was replacing the BEC I took a look at my rx. I cut open the plastidip and found water in there also. Got a new rx and bec and installed. Then I dipped each one 4 times letting them completely dry each time before I dipped them again. Took it out this morning and it still acts the same way. But its only when all the electronics are under water. As soon as I pull it out it quits glitching back and forth. Could it be because my antenna is being submerged. It is 2.4 and I have it laying down the frame.
02-01-2012, 10:40 AM | #16 | |
02-01-2012, 10:53 AM | #17 |
When yours did it, did it just stop or start glitching and going back and forth?
02-01-2012, 10:57 AM | #18 |
I have the antenna on my SR3100 tucked in the case and stored in the factory SCX10 box and I have NO problems putting the entire truck under water. Although water never actually touches any of my electronics otherthan my MMP and Novak motor. TapaTalk on Iphone4 |
02-01-2012, 11:10 AM | #19 | |
In the Scale Nats Top Truck Challenge 2010 there were several rigs that quit in the deep water hole, while others kept working. I don't know why though. | |
02-01-2012, 12:44 PM | #20 |
I think I will go ahead and place everything in balloons just to make sure and then reroute my antenna up a bit higher as well. If I haven't already fried something else. Anyone else using the plastidip having problems getting a good seal? After my rx went the only place I could think water could have came in is around the bundle of wires but I dipped them about 3 inches high also. I guess I will find out if it still works when I get home this evening.
brushed motor in water? - Similar Threads | ||||
WHAt brushed motor to use on 3S? | toy4crawlin | Electronics | 20 | 09-17-2011 06:04 PM |
running a new brushed motor in water?? | m1009cucv | Electronics | 2 | 07-06-2011 10:45 AM |
Brushed motors and water | KevMc | General Scale Talk | 8 | 04-26-2011 09:26 PM |
Brushed motor. | Synister_Intent | Team Losi Comp Crawler | 18 | 01-01-2010 10:43 PM |
What brushed motor on 3s? | Evandiego | Non Crawler RC's | 6 | 08-26-2009 09:14 PM |
