01-23-2012, 04:52 PM | #1 |
Quarry Creeper Join Date: Dec 2010 Location: gastonia
| AE2 servo..how high can I go
So who out there has tried there stock AE2 servo above 6 volts? How long did it last. I blew mine on my crawler and snagged it off my scaler and am gonna try to squeeze as much out of it as possible with out blowing it to. |
01-23-2012, 06:47 PM | #2 |
Newbie Join Date: Dec 2011 Location: Hampton GA
| Re: AE2 servo..how high can I go
It wont do 7.4 at tha twhen you turn it on it will blow so from 6 it is a 50/50 or keep it at 6.
01-24-2012, 12:10 AM | #3 |
I run my BEC at seven volts (7.0v), but then again I've also seen servo temps over 210°F. When I was trying to decide if I wanted to get a BEC, I put one of my 2S (500mAh) helicopter lipos in the receiver, and ran it that way for a pack or four. So I know it can take an unregulated Lipo (8.4v fully charged). My bushings have gotten horribly bagged out, to the point where I'd get the shakes when the steering centered, so I took out the bushings and put in 6x10mm bearings. Problem is, the bushings are 2.5mm wide, the bearings, 3mm, so the top of the case won't close all the way. But, it still steers just fine. Badmouth the 'stock' servo if you will, but I like the little bugger. Gots all the power I need, and has put up with everything I've put it through. That said, I do have a new Futaba HV servo on it's way here as we speak. |
01-24-2012, 12:37 AM | #4 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
im running the AS-2 in my honcho right now with a 2000mah nimh battery at 7.2v with no problems. servo is out of my ax10 RTC.
AE2 servo..how high can I go - Similar Threads | ||||
AE2 ESC issues | chopan84 | Electronics | 10 | 09-26-2011 11:39 AM |
ae2 esc | dracbec | Axial AX-10 Scorpion | 0 | 04-17-2011 11:40 AM |
ae2 | RCTRUX | Electronics | 4 | 04-06-2011 05:33 PM |
