01-26-2012, 08:06 PM | #1 |
Quarry Creeper Join Date: Feb 2008 Location: US
| ESC choice
Hello all, I recently had my FX-R catch fire. I think it is because my motor was clogged with mud/sand and drew way too much current. I feel that if I get an ESC with a heavier duty setup (burst rating) it'd be less likely to fail in this regard. I'm torn between a BR-XL and an MMP The nice thing about the BR-XL is that it can be ordered waterproof. But it is brushed only. The nice thing about the MMP is that it can run either but I'd have to waterproof it and I worry that it would want to overheat. -Is running a crawler as a trail truck on brushless lame? I know a lot of people say the low end resolution is poor, but many on here run brushless. The youtube videos I've seen don't seem to have terrible low end performance. -Have you seen a waterproofed MMP, do they run cool enough on say ~21T BL motors? |
01-27-2012, 03:48 AM | #2 |
Newbie Join Date: Nov 2011 Location: sidmouth devon uk
| Re: ESC choice
its quite easy to waterproof yourself, you can use the tried and tested ballon, epoxy, wrapped in a bag etc
01-27-2012, 03:45 PM | #3 | |
RCC Addict Join Date: Jul 2011 Location: Orlando
| Re: ESC choice Quote:
I have both ESC's and I can tell you if you plan on ONLY running brushed get the BR-XL. Its awesome! If you plan to run possible brushless then the MMP is perfect. I run an MMP with a ReVtech 21.5t Sensored BL motor and it works pretty damn good. Its currently being placed in my Wraith. Where the BR-XL is going into an SCX10 build with a good 35t brushed motor. Both ESCs have CC BECs as well so I dont draw any un-needed power away from them. I dont think you will be dissapointed with either of the two, it just depends on what your plans are. Good luck by the way I waterproof with balloons or radioshack project boxes and Liquid Electrical Tape. Works great. Also I have run the 21.5t BL motor and I run them hard with no heat issues. I think you would be fine with no issues regarding heat. just make sure you are geared properly. I also think using an external BEC reduces stress or heat on the ESC as well, might be something to think about. Last edited by AsILayDying; 01-27-2012 at 03:47 PM. | |
ESC choice - Similar Threads | ||||
Choice for ESC or ESC motor combo | fivepointnine98 | Newbie General | 10 | 07-05-2011 03:21 PM |
esc choice | beaven | Newbie General | 10 | 08-28-2010 11:14 AM |
esc choice | tas basher | Electronics | 0 | 10-08-2008 03:23 AM |
help with esc choice | rider12693 | Electronics | 3 | 09-24-2008 08:17 PM |
need help with ESC choice | Valtor001 | Newbie General | 6 | 01-03-2008 07:44 PM |
