01-27-2012, 10:10 PM | #1 |
Rock Stacker Join Date: Jun 2011 Location: Coquitlam
| Mamba max pro on 3's do i need external bec
Like it says, ill be running 3s mostly going to a hitech 7955 servo. Sent from my GT-I9100M using Tapatalk |
01-27-2012, 10:11 PM | #2 |
| Re: Mamba max pro on 3's do i need external bec
Yes with that servo you should use a BEC to get the most out of it.
01-27-2012, 10:13 PM | #3 |
Rock Crawler Join Date: Apr 2010 Location: Kelowna, B.C., Canada
You will defiantly want a bec for that servo, especially because you are running the mmp. The mmp has quite a weak bec, I think it is something like 1.5 amps. A servo like the 7955 can draw anywhere from 4-6 amps.
01-27-2012, 10:47 PM | #4 |
Yes...
01-27-2012, 10:51 PM | #5 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
No way. You should never run a BEC on anything ever. Why would Castle put one in the ESC if you needed to run a second one.
01-27-2012, 11:03 PM | #6 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
| Re: Mamba max pro on 3's do i need external bec |
01-27-2012, 11:15 PM | #7 |
Nice, bec just got hard wired in Sent from my GT-I9100M using Tapatalk |
01-27-2012, 11:52 PM | #8 |
01-28-2012, 08:38 AM | #9 |
Im gunna try both ways for a laugh, i use a 3" extension lead to solder my pos/neg to servo and run the signal straight to recievrr.... I can unplug it anytime Sent from my GT-I9100M using Tapatalk |
01-28-2012, 11:21 AM | #10 |
01-28-2012, 10:54 PM | #11 |
Switchy bit*h when i pin it.... Bec is a permanent fixture lol Sent from my GT-I9100M using Tapatalk |
Mamba max pro on 3's do i need external bec - Similar Threads | ||||
Mamba max pro BEC | RcBro | Electronics | 13 | 09-06-2011 05:21 PM |
Mamba Max Pro BEC Output Current? | Tommy R | Electronics | 4 | 05-06-2011 05:58 PM |
Mamba Max With External 10 AMP BEC | Firefox | Electronics | 6 | 06-10-2009 01:47 PM |
