01-30-2012, 05:08 PM | #1 |
Pebble Pounder Join Date: Oct 2011 Location: Kansas City, MO
| Couldn't find anything, so- Hobbyking branded servos... Thoughts?
Been on the lookout for some cheap servos for a Savage and a T-Maxx (both have used stock servos for some time before I've worn them out) to get them up and running again, and after doing some searching around, I've found these, in stock, in the US without a hefty pricetag. Given the specs and the appearance, it seems to be a pretty good bang for the buck, but I'm curious if anyone here has any experience with them (Hobbyking servos in general, not necessarily this specific model).
01-30-2012, 05:32 PM | #2 |
Newbie Join Date: Nov 2009 Location: Seattle, Wa
| Re: Couldn't find anything, so- Hobbyking branded servos... Thoughts?
for 20 bucks give it a whirl. I used a cheap hobbypartz servo that worked great for 3 years before i replaced it with an airtronics one i got for free
01-30-2012, 05:56 PM | #3 |
That's what I was thinking, so I already purchased two. I just figured since I couldn't find anything regarding any Hobbyking branded servos, I'd start a thread just to see if anyone would turn me away right off the bat or whatever. I'll report back and post how I feel about their quality and performance when I get them.
01-30-2012, 08:26 PM | #4 |
I bought a couple servos from HobbyPartz and they work well for the $15 or whatever I paid for them. Dont expect them to be Hitec 7950's or anything but they arent bad for the money. |
01-30-2012, 09:00 PM | #5 |
Quarry Creeper Join Date: Nov 2006 Location: out in boonies!!
Zeus I've been eyeballing that same servo you linked..you beat me to it, let us know how well it works out.
01-30-2012, 09:24 PM | #6 | |
| Re: Couldn't find anything, so- Hobbyking branded servos... Thoughts? Quote:
Sure thing. Only thing I'm possibly worried about right off the bat is the range of throw. I think it's something like 60* either direction from neutral. It'll probably be enough, but I know my Hitec 645MG and a couple other servos I had about 90*. I read that this might be able to be adjusted with end points but probably not. Last edited by Zeus.:God; 01-30-2012 at 09:29 PM. | |
02-02-2012, 08:40 PM | #7 |
Got my servos today. Both seem to work well. I tested them out on an old AM Futaba radio I had lying around as I'm waiting to get a couple more 2.4GHz receivers for my Airtronics (damn expensive receivers). They're 25 splines so Futaba/Traxxas horns work. Both work as advertised, with about 60* in either direction from neutral and plenty of torque to turn the tires on carpet (though the servo saver in my T-Maxx doesn't like it). I'm thinking I might be able to get more throw out of it with my end point adjustment on the Airtronics radio, as the servos will physically do 90* either direction of neutral. Unfortunately I won't be driving either very soon so durability is still unknown, though they seem nice and tight with good construction.
02-02-2012, 09:12 PM | #8 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
I love those servo's, I have them in both my 1/8 scale race trucks and my scaler, great servo's for the money. I have stripped one of them in my 1/8 buggy, but the servo saver was jammed solid and it stripped on a landing from a jump. |
02-02-2012, 09:46 PM | #9 | |
Speaking of servo savers, though, the stock Traxxas piece that came with my T-Maxx was WAY soft. Could turn the wheel on the remote and the servo would rotate, but the saver would soak it all up, turning the wheels only a little bit on carpet, and a little more on tile. Wouldn't even turn the wheels all the way if I rolled it on the floor. I swapped it out with a Kimbrough I had in my parts box and that was better, but not as stiff as I would have hoped. I don't remember these being so mushy in the past, and everything turns nice and smooth when disconnected from the servo. | |
02-02-2012, 10:23 PM | #10 |
Im sure they are fine. I will try them when my servo craps out
02-02-2012, 11:37 PM | #11 |
Has anyone happened to use Losi aluminum servo horns? I bought one to use in my Savage (only because they didn't have Dynamite), and the M3x10mm Traxxas screws I planned on using don't thread in. The threads in the horn look to be a coarser thread than the Traxxas machine screws. http://www.amazon.com/Team-Losi-Serv.../dp/B000P5PBYA EDIT: Just gonna' order a Dynamite arm. I can't find anywhere online stating what size and thread screws this thing requires, and the screw will be too small anyway. Last edited by Zeus.:God; 02-02-2012 at 11:50 PM. |
02-03-2012, 04:41 PM | #12 |
Quarry Creeper Join Date: Jul 2004 Location: Arkie-Saw
Being Losi its more than likely 4-40 if you say it looks more coarse. Will be a little smaller in dia as well.
02-03-2012, 07:45 PM | #13 |
| Re: Couldn't find anything, so- Hobbyking branded servos... Thoughts? |
02-03-2012, 09:51 PM | #14 |
02-03-2012, 10:56 PM | #15 |
| Re: Couldn't find anything, so- Hobbyking branded servos... Thoughts? Meh, no taps that small, let alone metric drill bits/taps, and part of the reason I wanted the threaded aluminum is so I don't have to deal with a nut. Already ordered the appropriate part and will get my money back on this.
Couldn't find anything, so- Hobbyking branded servos... Thoughts? - Similar Threads | ||||
hobbyking | S.C. yoda | Electronics | 25 | 12-19-2011 03:51 PM |
Hobbyking?? | rocksteadily | Electronics | 16 | 02-21-2011 06:05 PM |
Anybody use HobbyKing batteries? | RCAddiction | Electronics | 10 | 10-16-2010 05:06 PM |
Hobbyking | will1978 | Electronics | 19 | 07-09-2010 02:12 PM |
Servos: where to find torque specs? | TRA3905 | Electronics | 3 | 01-23-2008 02:47 PM |
