01-31-2012, 08:53 AM | #1 |
Quarry Creeper Join Date: Aug 2009 Location: Jackets are everywhere.
| Limits of Losi MSC12L?
Although it's rated for 2S, will it take more volts? Are ESCs more sensitive to over voltage, or is it the wattage that kills them when you go past ratings? |
01-31-2012, 10:11 AM | #2 |
Quarry Creeper Join Date: Aug 2009 Location: Phoenix
| Re: Limits of Losi MSC12L? Product Specifications Forward:Yes, proportional Reverse:Yes, proportional Time Delay Brake:Yes Input Voltage:4-cell (4.8 volts) to 7-cell (8.4 volts) DC NimH/NiCd or 2S (7.4 volts) LiPo Momentary Peak Current:1000A Forward and 350A Backwards Length:1.575 in (40mm) Width:1.575 in (40mm) Height:1.063 in (27mm) Weight:1.87 oz (53g) BEC Voltage:5V DC, 1 amp max. at 7.2V PWM Frequency:1kHz Overload Protection:Thermal Full On Resistance:0.0014 Ohms Forward and 0.0028 Ohms Backwards Based on the above specs 2S is the most it will take. |
02-04-2012, 09:17 AM | #3 |
I'm wondering if anyone tried 3s, and if it fried. I'd be running 1 per motor (45t), and as they are rated for 12t, I'm wondering if the low wattage used might let it work. I'm amazed at the amperage they claim these can run. |
02-04-2012, 10:20 AM | #4 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
they barely handle 2s. wouldn't take long at all to fry on 3s.
02-04-2012, 10:37 AM | #5 |
Pebble Pounder Join Date: Dec 2011 Location: Ridgecrest, CA
| Re: Limits of Losi MSC12L? |
02-04-2012, 10:46 AM | #6 |
30t brood handwound on 2s. esc was very hot to the touch. that was geared easy in an lnc. with a 27t stock motor, the signal wire torched off the board. they're junk esc's really. even pushing a 380 can motor in my vendetta mini buggy it ran hot.
02-04-2012, 12:09 PM | #7 |
I wonder if I cut a better heatsink, it would help. I'm running a pair in a MOA rig, and would really like to bump it to 9.6V (3 LFP).
