02-01-2012, 04:26 AM | #1 |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
| Axial LED controller putting out strange voltage. 15v wow
I am trouble shooting a problem with the front 2 LED lights on an SCX10. The tail lights work but the headlights don't. I took the controller out after inspecting all he wires for cuts.. All good. I pulled the little plug and tested for power and I get 15.2v holy crap!!! The tail light plug puts out 5v.. Here's the kicker. If I put the tail light plug in the head light 15v hole they work just fine, but the head lights still don't work.. Now I still may have a bad wire or LED on the headlights, but my mind boggling thing is the 15v output.. I'm only running a 2s lipo, how is this possible? Sent from my highly abused iPhone using Tapatalk |
02-01-2012, 09:18 AM | #2 |
Newbie Join Date: Jan 2012 Location: Etobicoke
| Re: Axial LED controller putting out strange voltage. 15v wow
White led's have a higher forward voltage. now my best guess on what would be easy to build from an electrical perspective is there is the led's in series and the led plug has a set current output. so yes a 15v output would make sense, along with why your rear lights work. chances are one of the connections for the led's is lose as led's rarely burn out. so yes i would suggest you check the connections along the line. As to the 15 volt... the simple answer is there is circuits you can make that will boost voltage. |
02-01-2012, 11:18 AM | #3 |
The voltage for the five string auxiliary lights is 18V. The rest are in the 5 to 6V range.
02-01-2012, 02:59 PM | #4 |
Found the led problem.. Wire broke inside the heat shrink at the LED.. As for the 15v... I had no idea it was supposed to be that high .. I thought an led had a range up to about 3.7 volts so 2 in series would require 7.4v. I built my own strings before.. I used 2 LEDs and a 62ohm resistor in each loop. Made four parallel loops. I accidentally hooked one up to a lipo without having the other hooked up and it let the smoke out of the one.. Sent from my highly abused iPhone using Tapatalk |
Axial LED controller putting out strange voltage. 15v wow - Similar Threads | ||||
Axial LED Controller w/Lights | DRW-FJ40 | Axial SCX-10 | 14 | 07-05-2014 12:20 PM |
Axial simple LED controller | neoakaj | Electronics | 6 | 01-14-2012 12:35 PM |
LED voltage help. | stelerzman | Electronics | 12 | 09-06-2011 04:18 PM |
