02-01-2012, 08:49 PM | #1 |
Rock Stacker Join Date: Jan 2012 Location: East stroudsburg
| Lipo charger question
Hey guys finally got me a lipo. So my question is about charging my battery is a turnigy 5.o It is a 2s 5000 mah 20-30 c what amp should I charge at? I was thinking 5 amps? Also I heare people talking about balancing I read up on it its to keep all cells equal and should I balance every time or run a few times then balance? also what do you balance at? Thanks for any help new to this just font wana mess up the battery just yet haha |
02-01-2012, 09:13 PM | #2 |
Quarry Creeper Join Date: Nov 2011 Location: Plano,TX
| Re: Lipo charger question
you should be able to charge at 5amps - but you may see your charger getting warm. I'd go a little lower 3.5 to 4.0. will take a little more time but it cant hurt. I balance everytime I charge. why not - its just a matter of plugging in a connector.
02-01-2012, 09:24 PM | #3 |
RCC Addict Join Date: Jul 2008 Location: San Diego
I read some where the first time to charge at 2.5 amps. Then after that charge at 5 amps. For the balancer you just plug the small connector into the charger and it will balance it. I charge all my batteries on my fireplace just in case.(brick) When your done with the battery. Put the battery in storage mode. It is a setting on your charger. |
02-01-2012, 10:17 PM | #4 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
i just got into lipo but have friends that have been running them for a long time.. here's my plan the charger i just bought only charges at .065amps and takes about an hour charge a battery. but if your charging at home charge at a lower amp like 2-3amps if your at a buddies house crawling charge it at like 4-5 amps so your not waiting all day on a battery to charge. when i go to a buddies house to crawl i'll most likely use his charger because it charges more than .065amps. he also has a $350 charger that goes up to 10amps, it will charge a 5s 5000mah battery in 30mins or something like that... to sum that up if you have the time charge at a lower amp if your at a buddies house crank that sucker up!!! |
02-02-2012, 10:50 AM | #5 |
For maximum battery life, I stick to "1C" charge rates, this means: 5000mah pack = 5A 1300mah pack = 1.3A Some packs can take a higher charge rate, but a 1C rate takes about an hour or a bit longer (if it needs lots of balancing). Since I have multiple packs, I charge the day before, then charge again the day of to make sure they're charged. Maybe 10 minutes is all it takes. I don't use a storage charge, but have not owned LiPO's long enough (~1 year) to see if this hurts overall life of the pack. |
02-02-2012, 06:53 PM | #6 |
Ok thx alot guys if im just doing quick charges I dont plug in the balancing plug? If im going to balance just plug it in correct?
02-05-2012, 10:25 PM | #7 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
I would plug the balancer in every time, it is there for a reason. I also charge my 5000mah Onyx lipo at 5.0Amps. No problems at all. My charger has super cooling fans! I use a Duratrax Onyx 245 dual charger! It is great for me. Last edited by ZippoMan; 02-05-2012 at 10:27 PM. |
02-06-2012, 12:00 AM | #8 |
Pebble Pounder Join Date: Oct 2011 Location: Kansas City, MO
Every 1000mah is 1 amp. 1C is whatever your capacity converts to in amps. My 5300mah battery would charge at 5.3 amps at exactly 1C, however you do not have to charge at exact C levels. My charger's max charge rate is 10 amps, so when I charge my battery, I just set it to 10 amps on balance and let it go, but the exact 2C would be 10.6 amps. I believe the Turnigy packs are generally rated at 2C maximum charge rate, but many/most people tend to charge at 1C due to fear of fire or shortened battery life, but 2C is typically regarded as safe on most current packs. ^Just what I've learned thus far in my short time with Lipos. |
Lipo charger question - Similar Threads | ||||
losi lipo charger question | b00sted08 | Newbie General | 6 | 01-02-2010 01:41 PM |
lipo charger question | ultimate_monkey | Electronics | 3 | 04-29-2009 09:17 AM |
MRC lipo and charger question? | rotten | Electronics | 3 | 03-21-2009 06:31 PM |
LIPO question and Charger.. | BIzzED | Electronics | 12 | 10-01-2008 10:22 AM |
7.4v LIPO and 11.1v Lipo and charger question and help. | 4x4Crawler4LIFE | Electronics | 5 | 02-27-2008 09:15 PM |
