02-02-2012, 12:38 PM | #1 |
| run time stock to novak scx-10
I have a stock dingo and a honcho with a rooster esc an a 55t novak motor. The honcho with 2.2, if that matters, runs for 10-15 mins an dies, I took that battery out an put it in my stock dingo an ran it for another 20+ mins. with more torque with a 27 t then the 55t novak in my honcho... Help! Could it be a bad motor? Wiring? Esc? I have a integy 35t on its way but don't want to toss the 55t if its not the problem.
02-02-2012, 12:45 PM | #2 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
| Re: run time stock to novak scx-10
what kind of battery are we talking about here, and what model rooster is it ? are you running a nimh battery in the lipo profile ? that would be allowing the esc to cut off at 6.25 volts. |
02-02-2012, 12:55 PM | #3 |
The rooster has a lipo cut off on it.. that plug is above the plug in I have its on. the particular battery is a 3300nihm... I have 8 batteries, ranging from 1500- 3300... Nicd an nihm. My two racers edge 1800 run it the best, longest, still not the power of the stock scx-10 motor...
02-02-2012, 01:11 PM | #4 | |
those two bottom pins you are referring to are actually to power a fan. here check this out and tell me if this is your esc. http://www.teamnovak.com/download/in...ter12T_ins.pdf Quote:
02-02-2012, 01:12 PM | #5 |
How do I test if It's the lipo cut off?
02-02-2012, 01:16 PM | #6 |
test it by visually checking to see if the LED on the esc is blinking and how many times it is blinking during your setup. follow the instructions on how to perform a one touch setup. |
02-02-2012, 01:44 PM | #7 |
It looks the same, mine says rooster crawler, on it.. still the same thing and setup? Which position/ number setting do I want it on? 1 or 3? I like reverse. ...
02-02-2012, 01:51 PM | #8 | |
seeing you have the rooster crawler you have another option. regardless i'm still pretty sure you would want option for profile number one. i downloaded and copypaste this for rooster crawler esc Quote:
02-02-2012, 01:59 PM | #9 |
Thank you for ur time, off to test It out!
02-02-2012, 02:02 PM | #10 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
i have the same esc. instead of fawking around with the manual i'll just explain it.. here's how to tell if your rooster is in nimh mode or lipo mode... i just remembered that i had mine in nimh mode and i was running a lipo so i did just this a few mins ago so i could give you some accurate info. with the rig turned off, plug in a battery, turn it on, press and hold little black reset button for a couple seconds let off, wait, if it flashes once your in nimh mode this is where you want to be. if it flashes twice your in lipo cutoff mode, press and hold the button again let off and see how many times it flashes, keep repeating this until it the light only flashes once. the rooster crawler has a lipo cutoff and if your running a nimh battery in lipo mode it will hit cutoff and act like the battery is dead. reset it like i mentioned and it should be good to go again. |
02-02-2012, 02:12 PM | #11 |
phew thanks dude, i was just thinking of getting on a plane and going to set it up for him. i haven't dealt with this yet, but i am switching over to lipo when my rig is complete so i am only web educated on this for now. thanks for putting it simple. |
02-02-2012, 04:05 PM | #12 |
There must be a delay, cause I was done by the time wannabe posted... I had no problem with getting it done. It still didn't change anything... It's still a laying dog... Any other suggestions?
02-02-2012, 04:55 PM | #13 |
maybe the motor is giving up the goat ?
02-02-2012, 05:14 PM | #14 |
crunky- hahaha well if setting up the esc didnt help then it could be the motor. do you have another motor that you could toss in just to try it out?? like the stock 27t or something?? a friend of mine had a 55t going dead in his ax10 a couple weeks ago and the truck was having troubles climbing and it was getting weak. |
02-02-2012, 06:13 PM | #15 |
Yeah I can through that in, I have a integy 35t coming to put in it. Hopefully soon... If It's the motor, is it worth rebuilding or just toss it?
02-03-2012, 06:30 AM | #16 |
55 turn motors are so cheap that unless it's a hand wound motor or something special like that I would just huck it out. After the battery stops working in the Novak, do you have a voltmeter you can toss on it to see what the voltage is ? |
02-03-2012, 02:59 PM | #17 |
^^^ i agree with that. if its not a handwound motor then just toss it.. 55t motors are like 50 bucks..
02-04-2012, 08:52 PM | #18 |
OK, so I did lots of reading after my phone fried from goin in the drink yesterday.. I drained an recharged batteries, put my gearing at 15t/86t an did some testing.. my run time has been great! Power has been ok but still not awesome, maybe I'm just expecting too much from it... 35t integy showed up today, maybe ill see more out of it then the 55t novak? I'll test once I wire it up an get back to ya...
02-04-2012, 08:53 PM | #19 |
And ill be getting a voltmeter shortly
02-07-2012, 04:05 PM | #20 |
Quarry Creeper Join Date: Mar 2006 Location: SoCal
You can always email Charlie, csuangka@teamnovak.com for assistance with Novak products.
run time stock to novak scx-10 - Similar Threads | ||||
Stock battery run time? | efnslammed | Axial SCX-10 | 8 | 11-29-2010 06:40 AM |
Creeper run time vs AX-10 run time | MikeSSS | Electronics | 2 | 09-02-2010 10:47 AM |
Average Run time w/ stock battery? | Planespotter | Losi Micro-Rock Crawler | 2 | 07-16-2010 02:23 AM |
stock battery run time? | always eating mud | HPI Wheely King | 12 | 07-19-2007 10:31 AM |
Run Time? | bcooper | Newbie General | 5 | 12-13-2006 10:42 PM |
