02-04-2012, 03:44 PM | #1 |
Rock Crawler Join Date: Aug 2008 Location: Bristol Va.
| BEC Help.....
OK, I hooked up my Castle BEC on my Wraith like it showed in the diagram, and removed the red wire from the ESC to RX. Now when I plug in the battery I have power to the lights and servo with the switch on the ESC off. And nothing to the motor until I cut the switch on. Is this normal? I'm running a Spektrum RX and have the BED in the AUX channel. I'm guessing it is, because the BEC is soldered to the battery and then plugged into the RX so you have power directly to it. Thanks Joe |
02-04-2012, 03:52 PM | #2 |
Quarry Creeper Join Date: Jan 2010 Location: USA
| Re: BEC Help.....
Yes, that is normal. The ESC gets its own power and is separate from anything that is powered from the BEC. That is why the red wire is removed, just to make sure they are separate.
02-04-2012, 03:58 PM | #3 |
Quarry Creeper Join Date: Oct 2011 Location: Detroit
| Re: BEC Help.....
Yep, totally normal. You are bypassing any BEC power from the ESC's by removing the red wire. The Castle BEC powers up as soon as you plug in the battery and, in turn, powers the RX and the steering servo (so I always turn on my radio before plugging in the battery). Sounds like you have it set up correctly. |
02-04-2012, 04:22 PM | #4 |
| Re: BEC Help.....
Thanks Guys. That's what I was thinking too, just wanted to be sure before I saw that "Magic Smoke". Now I think I will just cut the switch off |
02-04-2012, 07:55 PM | #5 |
Rock Crawler Join Date: Dec 2011 Location: Northwestern PA
| Re: BEC Help.....
I put a switch in my CC BEC power wire so I can switch it on and off without having to unplug the battery.
BEC Help..... - Similar Threads | ||||
BRXL+Castle Link+Bec=? How do i set BEC? | crazyorigin | Electronics | 17 | 11-21-2011 03:11 PM |
Built in bec vs. Rooster Crawler bec for glitching | mudking82 | Axial AX-10 Scorpion | 7 | 12-07-2010 08:57 AM |
using external BEC & esc's internal BEC.... | slowlearner | Newbie General | 2 | 02-14-2010 01:35 AM |
Castle BEC & Castle Link - not finding BEC | Locked Up | Electronics | 22 | 12-20-2007 03:37 PM |
Receiver BEC (vs ESC BEC) | sim | Electronics | 7 | 10-13-2005 07:54 PM |
