02-05-2012, 01:48 AM | #1 |
Newbie Join Date: Dec 2011 Location: Jacksonville , FL / Gatlinburg , TN
| Motor Connecters
Deans or Castle 4mm bullets for my ESC/Motor connecters ?
02-05-2012, 05:15 AM | #2 |
Quarry Creeper Join Date: Jan 2010 Location: Pennington NJ
I solder mine directly, but have heard others prefer the bullets.
02-05-2012, 05:37 AM | #3 |
Rock Stacker Join Date: Nov 2011 Location: St. Petersburg
| Re: Motor Connecters
i prefer deans when using brushed for easy swapping in the field, i always have a back up in case of smoke or dead brushes. when running BL, direct solder.
02-05-2012, 05:47 AM | #4 |
Quarry Creeper Join Date: Sep 2008 Location: Fab Shop
Maybe I'm old school, but I like Deans for brushed motors.
02-05-2012, 06:24 AM | #5 |
| Re: Motor Connecters |
02-05-2012, 09:17 AM | #6 |
Rock Crawler Join Date: Nov 2009 Location: Commiskey
I use the bullets. I like being able to remove just the motor or esc from the rig if I have to and not have to remove both everytime if either needs servicing or replaceing.
02-05-2012, 09:21 AM | #7 |
Rock Crawler Join Date: Oct 2006 Location: Fernley
02-05-2012, 09:52 AM | #8 |
02-05-2012, 09:54 AM | #9 |
i always use 3mm or 4mm bullets on all my motors for easy removal instead of having to heat op the soldering iron. deans will work too, just make sure its opposite of your battery connection so you cant accidently hook the battery to the motor wires
02-05-2012, 10:02 AM | #10 |
Newbie Join Date: Dec 2011 Location: BC, Canada
Yup, bullet connectors on all my models. I can swap ESC's and motors around very easily. Best to stay consistent with these connectors and your batteries.
02-05-2012, 06:09 PM | #11 |
Thanks for all the replies . Think I'm gonna use my Castle 4mm Bullets . I usually solder my motors on race setups but on crawlers and bashers I like the convenience of connectors . Also like the idea of being able to change the polarity with the bullets without having to break out the soldering iron . Thanks again .
Motor Connecters - Similar Threads | ||||
solder vs. connecters | andypants | Electronics | 11 | 02-02-2010 04:43 PM |
Output/shaft connecters. | Charger | Newbie General | 2 | 12-27-2006 08:07 AM |
