02-08-2012, 03:26 AM | #1 |
Rock Crawler Join Date: May 2007 Location: Norwich
| Thinking about a Futaba 6exp - should I?
So two main questions - Can a Futaba 6exp be used to control a dual esc Moa? And if so would the 603ff be compatible with it (I'd use the 6 channel rec with the moa and the 603ff with my scaler) Any help would be greatly appreciated |
02-08-2012, 06:12 PM | #2 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
| Re: Thinking about a Futaba 6exp - should I?
Is the 6exp the same as a 6ex? Twin stick right? I run one to control dual esc's on my XR. Im not sure what rx's will work. My guess would be that if it is for the faast system and made by Futaba it would work.
02-09-2012, 02:23 AM | #3 |
Rock Crawler Join Date: Jan 2009 Location: Christchurch, New Zealand
Hey guys, The 6EXP is a 72MHz unit. The 603FF is for 2.4GHz units, so not compatible. Check here for all the Futaba stick radios > FutabaŽ Aircraft Radio Control Systems and Accessories I recently set up a 8FG for a friend and these look to be a great option for crawling. Plenty of 3 way switches and programming options for MOA's and the like. Personally, I'm running a 10CG and loving it. If only the 8FG was available when I was looking... Cheers, Mike. |
Thinking about a Futaba 6exp - should I? - Similar Threads | ||||
R2D / Futaba 6EXP | Marcomi | Electronics | 0 | 02-07-2008 11:21 AM |
