02-08-2012, 05:45 AM | #1 |
Rock Stacker Join Date: Mar 2011 Location: oconee
| hitec 7950 water resistant?
Just curious if any of you guys had any experience with this servo I don't wanna submerge it I just like to be able to rinse my rig off before bringing it In the house. Its quite a an expensive servo and don't wanna ruin it thanks in advance
02-08-2012, 08:02 AM | #2 |
RCC Addict Join Date: May 2010 Location: Midwest
| Re: hitec 7950 water resistant?
I would say that most servos are water "resistant", because of their tight case/enclosure. If you spray a hose directly at it, I would expect water to get in. I would feel ok with washing my rig without streaming water directly at the servo but, if some splash gets on the servo, no big deal. |
02-08-2012, 08:23 AM | #3 |
RCC Addict Join Date: Aug 2009 Location: Earth?
It has rubber seals yes. Ive had mine under water briefly while driving through water quikly. Dont think Im gonna just sit in the water waiting to see if its water proof though.
02-08-2012, 08:37 AM | #4 |
Quarry Creeper Join Date: Feb 2011 Location: Wellford, SC
Haven't dunked my 7950 but I did dunk my 7954 for about 10 minutes. My crawler fell into water between large rocks through an opening not large enough for me. I had to go to the car to get something to reach it to retrieve it. It soaked up water everywhere. The servo did not drain very fast either. I had to disassemble it to remove the water and after drying and getting it back together it has been fine. No problems. I agree that splashing water would be fine and I have seen others get dunked for just a few seconds during a run with no problems at all.
02-08-2012, 08:37 AM | #5 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
they do have rubber seals, and i've been told by a hobbyshop employee that they are "water proof" I wouldn't submerge them but I would say they are water resistant.
02-08-2012, 08:52 AM | #6 |
There are 2 of them hidden on this rig.... |
02-08-2012, 09:10 AM | #7 |
Pebble Pounder Join Date: Jun 2007 Location: Sacramento
Some marine grease on the servo spline helps water not get through the geared area, otherwise the rest of the casing has seals.
02-08-2012, 09:18 AM | #8 |
RCC Addict Join Date: Feb 2008 Location: Nevada
| Re: hitec 7950 water resistant? That's what my comp rig looked like, on my last comp the part that was scary was.... the last time i took the servo apart, I was in a hurry and the rubber seal wasn't in the groove, the top half of the rubber was sticking out I found this out after, i pulled it out of the water. I must have had the two halves pretty tight though, because i have had 7 battery packs in it since then, with no issues |
02-08-2012, 10:11 AM | #9 |
Thanks guys that makes me feel much better ill be installing it shortly. Do I Need a BEC. Or will the AE2 be enough?
02-08-2012, 10:23 AM | #10 |
Rock Crawler Join Date: Aug 2010 Location: Socal
The 7950 loves the power. BEC set to at least 6 volts. I have always had mine at 7.4 volts with no problems on my comp rigs. Unless you are running a 2s lipo then you can just run it straight off the battery with only the signal wire plugged into the reciever.
hitec 7950 water resistant? - Similar Threads | ||||
Is the Hitec HS-7955TG really water resistant? | kitsched | Electronics | 5 | 01-23-2012 07:42 AM |
how water resistant? | rushton123 | Redcat Crawlers | 6 | 05-31-2010 09:22 AM |
When Traxxas says Water Resistant They Mean It | nascarkeith | Chit Chat | 4 | 02-01-2010 08:54 AM |
Water Resistant Servo? | ArmyStrong | Electronics | 4 | 01-28-2010 08:42 AM |
