02-24-2012, 01:20 PM | #21 |
Pebble Pounder Join Date: Nov 2011 Location: Kittanning
| Re: Lack of torque. Is it the motor or battery?
ya, ok i understand that... but any good motor/ or hand-wound motor require more amp draw.. ask the gents with the 7t puller motors... so if he has a nice 35t hand-wound he is drawing some amps there.. more then a normal integy 35t
02-24-2012, 03:39 PM | #22 |
Rock Crawler Join Date: Nov 2009 Location: poteau
i think the concept your failing to understand is the esc gets it's power from the battery. the motor (whatever you run) draws power from the battery thru the esc. without an external bec the esc also has to supply the servo with power. this is where brown outs can occur. when you install a bec the servo draws it's power from the battery thru the bec and reciever. the esc no longer supplies any power to the servo. it's only job is to power the motor. the bec voltage has no bearing on how much amperage or voltage goes to the motor. to the OP, when you installed the bec, how did you wire it up? if you wired it per castle instructions, you did remember to pull the RED wire out of the esc plug didn't ya! |
02-24-2012, 06:12 PM | #23 |
Newbie Join Date: Jan 2012 Location: Houston
Yea i wired it like the instructions told me to, yeah i pulled the red wire. I turned the steering dual/rate down some and it feels alot better ALMOST perfect but it did give out on me a couple of times. Mainly because I was pushing it trying to see what it was capable of, it seems like the warmer the motor gets the worse it gets. Just hate to sacrifce turning radius for what I thought the bec was going fix to begin with.
02-24-2012, 07:24 PM | #24 | |
| Re: Lack of torque. Is it the motor or battery? Quote:
With the power off in the rig, move the steering through it's whole range from side to side noting where it binds. Then power the rig up and set the steering EPA's just short of where the steering binds. | |
02-24-2012, 08:46 PM | #25 |
problem is charlie is he is running the stock axial radio. it doesn't have epa settings on it. just steering trim, throttle trim, and steering dual rate. the bec should have fixed any overcurrent amp draw from the servo causing your problems. like i said before if you stall a motor it doesn't take long at all to do damage. without getting to technical when the motor stalls it's drawing MAX current. this current has to go somewhere it just doesn't disappear, and will cause damage to the motor. we can get all techy and tell ya what exactly is getting damaged, but you really don't care about that unless your gonna get into motor rebuilding and such. just know that every time you stall the motor it's not good, and will cause the motor to either get weaker each time, or if its bad enough or long enough will cause the magic smoke to come out. if you have a place to test things, take the truck out and get it to where it usually stalls the motor. now pull the servo plug out of the reciever and see if the truck still stalls in the same spot. if so then it's the motor, if not then you may have a servo current draw issue. did you check the motor for timing?? |
02-24-2012, 08:53 PM | #26 | |
OP, you could also try using a shorter distance from servo center to drag link mount distance. This will drop the servo throw a bit (at the knuckle). | |
02-25-2012, 12:08 AM | #27 |
Pebble Pounder Join Date: Sep 2010 Location: Lees Summit
| Re: Lack of torque. Is it the motor or battery? We aren't saying to just turn it down farther. You shouldn't be sacrificing much at all by turning it down. You just need to turn it down to stop JUST BARELY before it gets to a mechanical lock. You don't want your servo to try to fight against the point where it can no longer physically move. Even without specific EPA adjustments, you should be able to get pretty close to the stops with the dual rate (on one side, anyway).
02-25-2012, 01:51 AM | #28 |
The AE-2 is rated to run on 3S with the use of an external BEC. I would drop your gearing a little bit and move up to 3S packs, you will like the difference! |
02-25-2012, 09:19 AM | #29 |
according to what axial sent me the ae-2 esc is only rated to 2s lipo. they even made the comment that it's written on the esc itself! they also told me that they would NOT warrantee the ae-2 esc if it was ran on 3s lipo. that being said i ran my wraith on 3s, and am running my ax10 on 3s both with a stock ae-2 esc without any problems so far. i am running the CC bec also. just want to get the correct information out there straight from axial customer service. mine tho runs well on 3s lipo and the power difference is great! |
02-26-2012, 01:22 PM | #30 | |||
It all boils down to the internal BEC. A BEC does produce heat, and has some maximum input voltage rating. The heat produced will add to the heat generated by the ESC parts. With high voltage feed and power drawn both parts will cause a heat build-up, that might cause problems. As for "brownouts", since both the ESC and BEC (internal or external) are fed from the same battery any drop in battery voltage will affect both parts. (The motor will be affected more directly though, since it's often fed the full voltage. The BEC is there to reduce the battery voltage and will just draw more current from the battery if the voltage goes down.) | |||
02-27-2012, 11:45 PM | #31 | ||
Yeah i checked the timing, its at 0 I'm thinking a higher torque servo might do it along whith a higher voltage battery It seems like its some sort of voltage issue. | ||
02-28-2012, 02:35 AM | #32 | ||
From their web site: (Axial AE-2 ESC Set-up and Programming) Input Voltage - 6 cell NiCad/NiMH or 2cell lipo** **You can run higher voltage batteries such as a 7 cell NiCad/NiMH or 3 cell lipo with the installation of a “Castle BEC” Maybe you should point that out to their customer service next time you speak with them about this issue. Not saying it is "right" but there is technically no way (that I know of) for them to tell what voltage you were running so I can't see how they could deny warranty based upon you running 3s...Obviously if you ran something crazy like 6s they would probably be able to tell. Anyone who has issues with them not honoring warranty repair/replacement based on running 3s on the AE-2 please direct them to the link I posted above. I didn't see any mention of voiding the warranty by using 3s in that link. I would bet that the warning is just a "Cover Our Butt" warning intended for people with little/no RC experience picking up a RTR version including the AE-2. Note:I personally don't have a AE-2 so I am going by information posed in that link, I can't comment on information contained in the user manual or any other source. Quote:
This is the deal with brownouts: The RX looses power for a finite amount of time when you overpower the BEC (internal or external) and this creates problems for everything that needs input from the RX/TX. Depending on how long the RX looses power this could be just a little hickup or it could be bad enough that the ESC will have to rearm when the RX comes back on line. You may also notice that the servo will center for a moment when power comes back on even if you are steering to one side. The real problem with internal BEC's is that they aren't rated to handle the required amperage ouput that the servo is pulling. Typically your standard internal BEC is rated to 3-5a @ 2s, as the voltage increases the amperage rating on the BEC decreases...Nothing good there. Of course there is also the issue of extra heat and that should not be overlooked but the limited amperage output is the real killer. A ESC like the Holmes BR-XL has a 10a BEC internally and there is no need to run a external BEC when running that ESC. OP: If you arent already running an external BEC you would probably benifit from running one even if that doesnt "solve" your issues. It is $20 well spent. I still suggest reducing you gearing a bit to see if that helps. Of course if there isnt enough power to overcome the bind the the rig will just sit there and try to go, I would volt up and gear down you will gain some power down low and gain some wheelspeed...Best of both worlds! Last edited by SMR 510RR; 02-28-2012 at 02:40 AM. | ||
02-28-2012, 07:16 AM | #33 | |
In a way, it's a poor way to do the same as setting a lower value in the TX for steering EPA's. Make a bit more sense now? | |
02-28-2012, 10:44 AM | #34 | |
02-28-2012, 11:14 AM | #35 |
| Re: Lack of torque. Is it the motor or battery? |
02-28-2012, 11:16 AM | #36 | |
The only reason TX EPA can be better is if you want to remove/change the limitation during a run. | |
02-28-2012, 11:27 AM | #37 |
| Re: Lack of torque. Is it the motor or battery? Or have different values left and right...I dont know about you but I have never had a servo horn line up just perfectly so that everything is centered out of the box.
Tags |
2s lipo, 30c, battery, motor, torque |
Lack of torque. Is it the motor or battery? - Similar Threads | ||||
HH torque master battery size | the a team | Electronics | 4 | 09-04-2010 06:31 PM |
EVX Dual Motor combo... lack of rear power | Twiztid Metal | Electronics | 1 | 08-28-2010 08:18 PM |
AX10 motor?? and motor turns speed vs torque | landy-ross | Electronics | 16 | 06-19-2008 12:50 PM |
Motor torque | RichieOTR | Electronics | 6 | 05-14-2007 09:16 PM |
Stock LEO X - lack of torque !! | Uthaya | General Crawlers | 10 | 08-24-2005 07:53 AM |
