02-11-2012, 10:37 PM | #1 |
Pebble Pounder Join Date: Oct 2011 Location: Exeter Ontario
| Still no Steering. SOLVED
Starting tofeel like a menice but GT3B, Dual No Name ESC, CYS S0150 Servos. Everything works except for both front and rear steer. I connected my front servo to another RC and TX/RX and it worked. They worked at one point when I was just finishing things off with a 3ch RX. Did I fry something in the ESC's? Do I a BEC (or 2 with the 4ws?)? Last edited by JKMotorsports; 02-15-2012 at 05:14 PM. |
02-12-2012, 01:00 AM | #2 |
Quarry Creeper Join Date: Dec 2011 Location: marshall
| Re: Still no Steering.
alot of no name esc's don't have an internal bec, thats probely the case here
02-12-2012, 01:11 AM | #3 |
Maybe this will help... GT3 no enter or trim buttons? |
02-12-2012, 07:26 AM | #4 |
the have a built in 6v bec and they did work up until 2 days ago.
02-12-2012, 02:04 PM | #5 | |
| Re: Still no Steering. Quote:
I can honestly say I haven't seen a non-BEC ESC in a decade or 2 or close to 3. If you know of a single one, please let me know! My 1st BEC ESC was early 80's (Novak), as far as I know, pretty much any ESC from the late 80's onward have an internal BEC. While they may suck for high draw crawler servos (over ~200inoz), they are fine for a RX. | |
02-12-2012, 02:07 PM | #6 | |
Are you sure you plugged the servos in correctly?? (dark wire.....brown or black....towards the outer edge of the RX). | |
02-12-2012, 03:35 PM | #7 | |
Castle Creations | One Cell Mamba Max Pro 1/10th Scale ESC The issue seems radio related, do you have throttle control? What if you plug the servo into the throttle channel? Does it work then? | |
02-12-2012, 03:40 PM | #8 | |
| Re: Still no Steering. Quote: I would bet the circuit is there, just turned off. Regardless....yes, I now have a spec that shows a "non-existant" internal BEC. Sigh. Thanks SMR. [Stupid in my mind....but I'm a field/service guy....NOT a sales guy......] | |
02-12-2012, 04:44 PM | #9 |
| Re: Still no Steering. Nope wrong again, says in the link "These controllers will have their BEC circuit disabled - removed actually - so you will need an outboard 4.8 - 6.0 volt power source to run your electronics. We recommend a CC BEC with a small 2s LiPo or a separate 4/5 cell NiMH receiver pack." |
02-12-2012, 05:16 PM | #10 | |
Bang head...... | |
02-12-2012, 05:28 PM | #11 | |
Sucks as i wanted it running the upcoming weekend and no online shop can get a bec to me by then and no lhs within a one hour radius. | |
02-12-2012, 05:46 PM | #12 |
Sooo....you're running dual ESC's....did you have both red ESC to RX wires connected?? You should only have ONE red wire feeding the RX (either from an ESC or an external BEC). If running dual ESC's, it's best to remove one red ESC to RX wire from the connector & tape it up. |
02-12-2012, 05:48 PM | #13 | |
You sure you have the servos plugged in correctly? They arent backwards? They arent in the wrong slot? It sounds like you are running dual ESC's and 4ws...Have you tried using a fresh model to see if you got your programming for the servo wrong? You just need to keep crossing possible causes of the list until you find the one thing that is not correct. No one here is going to be able to just tell you what it is, all of these problems are specific to your exact setup so without the truck in front of us its hard to figure out. So far we know:
Keep adding to that list until you find the problem. Last edited by SMR 510RR; 02-12-2012 at 05:53 PM. | |
02-12-2012, 06:00 PM | #14 |
Is your servo plugged in backwards? Black wire to the outside
02-13-2012, 07:00 AM | #15 |
Well last thing to try is different servos as I get nothing plugging them into the rear esc channel. Yes they are plugged in right.Checked, double checked andeven tried it the other way. I will be getting a bec, just no lhs so I either got to go into the city or order online. How many amp should I go for? |
02-13-2012, 07:22 AM | #16 | |
Most of us use the Castle Creations 10A BEC. I wire it direct to the servo, others (and CC in their directions) run it through the RX. | |
02-13-2012, 10:02 AM | #17 |
Well if it was an RX issue withthe steering channels would the servo not function when plugged into a motor ch? Also it did the same thing when I was rear steer delete and using a 3ch reciever. It literally worked one day and not the next. I was hoping it was my old RX but it was not. I have reloaded radio firmware and went through losikids step by step setup and nothing. Plus CH1 should be steering by default and it doesn't work also. |
02-13-2012, 10:22 AM | #18 | |
Maybe I missed something? Plugging the servo into the RX and trying to "steer" using the throttle on the TX should make it work (since you say the ESC's work). | |
02-13-2012, 11:58 AM | #19 |
Right. It does. I'm starting to loose track of what I've done.
02-13-2012, 12:54 PM | #20 | |
Still no Steering. SOLVED - Similar Threads | ||||
BTA steering vs regular steering | daniel15fl | Venom Creeper | 44 | 11-08-2010 11:22 PM |
inside tyre touches steering knuckle / steering linkage | murky123 | Axial SCX-10 | 4 | 10-06-2010 04:46 PM |
Getting more steering from the Bully axles after Modding for more steering | jcboof | RC4WD Bully | 15 | 01-31-2010 10:01 PM |
Hot Racing Steering knuckles - more steering than the original plastic ones? | Tomy | Axial AX-10 Scorpion | 1 | 11-16-2008 11:26 AM |
