02-20-2012, 07:42 PM | #1 |
Quarry Creeper Join Date: Apr 2009 Location: Ottawa, ON, Canada
| 4PL Throttle Trigger Travel Mod
I've had the 4PL for nearly a year now so I'm due to make a mod and void the warranty ;) One thing I quickly noticed with the transmitter is that the reverse travel of the trigger is much shorter than the forward. This is fine for boats or cars that only use brakes, but for crawlers and scalers I find it limits low speed control in reverse. I took measurements with a protractor to find out what the stock unit offers. I found the forward/reverse ratio to be about 75/25 (30 degrees forward, 10 degrees reverse). I'm used to my old radios that gave me 50/50 so I set out to change it. The third picture above shows where it is being limited on the back stroke at the blue arrow; it's not even reaching the mechanical ATL screw at the red arrow. I decided to trim these two areas to maximize the travel. But first I had to make sure the radio could get 'adjusted' to the new throttle travel. I took apart the trigger mechanism, took note of the pot (potentiometer) position at the reverse position and removed the trigger from the pot. I then went through the Adjuster process (p. 97 in the 4PL manual) turning the pot further back than I was planning for test margin. The radio had no problem adjusting, so all looked good and out came the X-Acto knife. I trimmed the areas shown in blue and red below; I didn't remove the whole rib as I figure it's there to add stiffness. I re-measured the back stroke and figure I gained about 80% travel. Still not 50/50 but way better. I re-assembled the radio and went through the Adjuster sequence a final time. Driving my cars I can really feel the difference, I have much better control in reverse than before. The nice thing about this mod is that if you don't like it afterwards or your radio can't adjust to the new reverse position, you can use the mechanical ATL screw to push it back, which makes me wonder why Futaba limited the stroke so much in the first place. If you don't want to push the reverse stroke back like I did but still want a lower forward/reverse ratio, you could try adding a spacer at the yellow arrow shown in one of the pics above. This would push the neutral position forward reducing the forward stroke and incresing the reverse stroke at the same time. You'd need to go through the Adjuster sequence afterwards, oh and don't make it permanent until you're sure the radio will accept the new neutral position! Richard |
02-21-2012, 06:34 AM | #2 |
| Re: 4PL Throttle Trigger Travel Mod
Nice write-up, I'll pass it onto my son since he runs a 4PL. |
02-21-2012, 10:30 AM | #3 |
Rock Crawler Join Date: Sep 2011 Location: truckee
hey thats pretty cool. thanks for sharing. i need to do this once my warranty is up.
02-21-2012, 01:37 PM | #4 |
RCC Addict Join Date: Apr 2010 Location: Ringwood
cool but i cant see the pics
02-21-2012, 02:28 PM | #5 |
| Re: 4PL Throttle Trigger Travel Mod |
02-21-2012, 02:33 PM | #6 | |
| Re: 4PL Throttle Trigger Travel Mod Quote:
I also see my son found my email! [I see the pictures.....] | |
02-21-2012, 04:00 PM | #7 |
I'm using chrome but on my iPod I can see them I'll just use my ipod
02-21-2012, 04:36 PM | #8 |
02-21-2012, 04:50 PM | #9 |
Mod is done since I have pulled my radio apart before it took about 5 mins and can't wait to try it
03-29-2013, 01:14 PM | #10 |
Pebble Pounder Join Date: Mar 2012 Location: Upstate New York/Newfoundland
I did this mod but also added a shim to get it closer to 50/50 (white styrene in pic). Its near spot on now but I found I could not calibrate it by using the adjuster mode after adding the shim. The pot reads full throw a short ways before it mechanically bottoms out in reverse. I still use it this way tho as it still works just fine with all my novak esc's after doing the 1 touch programming. |
08-10-2013, 08:00 PM | #11 |
Finally did this. Wish i would have done it a long time ago, literally took 5 minutes. Reverse is a lot smoother now. Thanks again YJ_Driver. Now i need to figure out the 3 position momentary switch mod.
02-01-2015, 02:46 PM | #12 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
Thanks for posting. I'll give it a try.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/367623-4pl-throttle-trigger-travel-mod.html | ||||
Thread suhl 150 trigger travel | Benchrest Central Forums | BoardReader | This thread | Refback | 02-26-2013 10:27 AM |
4PL Throttle Trigger Travel Mod - Similar Threads | ||||
4PL throttle issue | rcscaler | Electronics | 11 | 01-09-2012 05:46 AM |
Dx6i without throttle return mod? | huckfinn220 | Electronics | 9 | 09-04-2009 10:38 AM |
Throttle travel on radio? What does it change? | BigB_117 | Electronics | 10 | 05-05-2009 01:32 PM |
dx7 throttle mod ? | curve | Electronics | 0 | 01-15-2009 04:45 PM |
DX6 mod throttle springs? | emaxxjeremy | Electronics | 1 | 10-24-2006 04:53 PM |
