02-22-2012, 06:25 PM | #1 |
Newbie Join Date: Dec 2011 Location: Soddy Daisy
| A budget servo instead of the Hitec 645mg My son has stripped the gears out his Hitec 645mg for a 2nd time. Looking to go with something with a little more beef but not break the bank. I think all the steering is setup correct? It does have some brass inserts in the wheels(6.5oz per wheel). |
02-22-2012, 06:27 PM | #2 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
| Re: A budget servo instead of the Hitec 645mg
how old is your son? and how does he drive. a servo saver may save you both alot of headach. your not going to get away from the stripped gear problem with another "cheap" MG servo, you will want to go to steel or perferbly titanium gears. |
02-22-2012, 06:30 PM | #3 |
He is 8 and drives it like he stole it!
02-22-2012, 06:33 PM | #4 |
| Re: A budget servo instead of the Hitec 645mg |
02-22-2012, 06:36 PM | #5 |
| Re: A budget servo instead of the Hitec 645mg thats why they made servo savers and slipper clutches seriously though you're going to have to use your judgment, you dont want to spend $80-140 on a servo that wont last with him driving. a hitec 7954, or 7955 might be in order. (bluebird makes a few cheaper options aswell available on hobbyking, but then replacement parts and warantee are pretty well out) I personaly run a bluebird servo on my XR10 and like the performance so far. BMS-2514 Coreless Digital Alloy Gear Servo - 25.5kg I will be replacing it soon with this one. (when stock comes in) BMS-35A High Voltage (7.4V) Brushless Digital Servo w/Titanium Alloy Gear 35.5kg |
02-22-2012, 06:39 PM | #6 |
First question.....are the steering EPA's correctly set-up? It's easy to overload the servo if it tries to overdrive the steering linkage.
02-22-2012, 07:15 PM | #7 |
| Re: A budget servo instead of the Hitec 645mg It came with a Traxxas Link 2.4ghz 2 channel radio setup. I went through the setup to set end points? Will definitely check that again. |
02-22-2012, 07:27 PM | #8 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
A nice one can easily be had here in the classifieds as well Nose around and see what you come up with |
02-22-2012, 07:34 PM | #9 |
Pebble Pounder Join Date: Nov 2011 Location: Kittanning
i bought the HobbyKing R/C Hobby Store : HK15298B High Voltage Coreless Digital MG/BB Servo 66g / 20kg / 0.16s (USA Warehouse) and i love it... its a lil loud.. but the power is there when u need it.. and its safe to run off 2s |
02-22-2012, 09:43 PM | #10 |
RCC Addict Join Date: Jan 2007 Location: Bouldertown
I am surprised no on has stated a 645mg IS a budget servo!
02-22-2012, 09:45 PM | #11 |
RCC Addict Join Date: May 2010 Location: Midwest
02-23-2012, 06:40 AM | #12 |
I have been messing around with Hobbyparz Solar 770 servo in my AX-10 and so far it has been OK for a $23 servo pushing 400+ oz/in @ 7V. It is noisy and slow but it does work. The only problem is buying one, it seems they're always out of stock. |
02-23-2012, 07:17 AM | #13 |
Newbie Join Date: Jan 2012 Location: kincheloe
i have found one on ebay that i use it is good i was not sure when i frist bought it but now it is all i use it has titanium gears and water proof they havent falled me yet i will include the ebay number for you to check it out you will like it if you give it a try and its onley 38 bucks 320739382853 have fun and good luck
02-23-2012, 09:46 AM | #14 |
RPP sells rebuid gears for the 645 for 12 bucks. i ran the 645 for over a year on my SCX10 before it stripped. maybe theres another problem
02-23-2012, 07:16 PM | #15 |
Get a servo saver. It'll be the best $10 you'll spend on a component of an RC car for a kid. The Kimbrough HD or equivalent would be good. Oh yeah, a Futaba 3305 is a decent budget servo, ~$35. I run them on a 1.55 scaler and a 2.2 basher. The basher has a servo saver on it and I'm not a kid. Last edited by Manning; 02-23-2012 at 07:19 PM. |
02-23-2012, 07:34 PM | #16 |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
Sorry to butt in... I have a couple kimbrough servo savers but find them really weak.. Is there anything out there that's a little better but still does a decent job at saving gears. My wraith is a servo killer.. Ive tried many things but all seem to fail.. Even my 7954sh stripped.. Sent from my highly abused iPhone using Tapatalk |
02-24-2012, 06:55 AM | #17 | |
| Re: A budget servo instead of the Hitec 645mg Quote:
Servo savers are more for go-fasts that get huge shock loads when you hit something while moving fast. | |
02-24-2012, 09:42 AM | #18 |
The small Kimbrogh's are indeed too weak for crawlers. The large white ones are much stiffer, then the Heavy Duty gray one is stiffer yet. . Kimbrough part # 124 is the one you want for a crawler. |
02-24-2012, 10:35 AM | #19 |
Thanks Sent from my highly abused iPhone using Tapatalk |
02-25-2012, 02:13 AM | #20 | |
RCC Addict Join Date: May 2011 Location: Utah County
Sent from my ADR6400L using Tapatalk | |
