running leds and cree lights from fourth channel on receiver?
I have an extra receiver channel on my receiver. Ok...the plan is to put several lights in. Id like to put in (all 5 mm led) four white rock lights...four red brake lights...one or two blue safety lights. I also wanna put in two t15 cree lights for headlights (these are normally used to replace license plate lights on a car). Question is can I wire all these together to a switch and run them from the fourth channel on the receiver and power them all? Or should I seperate the leds from the cree lights and run a seperate power source to each ( the ten leds...and one for the cree)? BTW Im running 3s 30c 2800 mah lipo
Re: running leds and cree lights from fourth channel on receiver?
What you need is an RC switch, Heyok is a vendor on here and he makes all kinds of switches and lighting controllers...Hit him up and he can get you what you need.
As far as all of your lighting needs, you will have to do some calculating and figure out the best way to proceed. It makes a big difference if you plan to wire up your own LEDs or if you are going to buy prefabricated ones that RC manufactures make. |
