Thread: servo- how much is enough?
Old 02-22-2012, 09:46 PM   #1
Default servo- how much is enough?
How much torque should I be looking at? for a scaler, not a comp rig. I was thinking a wing servo that some of the jet guys use small, flat easy to hide, lots of torque. I just dont know how much torque is enough?
L.R.
LoneRanger is offline   Reply With Quote
Old 02-22-2012, 10:00 PM   #2
Default Re: servo- how much is enough?
L.R.
I would have at least 175oz
My op.
holycaveman is offline   Reply With Quote
Old 02-22-2012, 10:11 PM   #3
ScaleFreak93's Avatar
Anything less than 400oz is useless
jk. You need 125oz or more to be on the safe side. I run a 240oz in my scaler personally.
ScaleFreak93 is offline   Reply With Quote
Old 02-22-2012, 10:28 PM   #4
suggestions on the smallest 125-150oz servo? digital or no?
L.R.
Old 02-22-2012, 11:00 PM   #5
I recommend 200+ for a 1.9 scaler.
Most of the servos we use are all the same size externally...They are "standard size". Make sure whatever you get has all metal gears or you will blow it up quickly.
SMR 510RR is offline   Reply With Quote
Old 02-22-2012, 11:08 PM   #6
Didn't see what you are running it in. mrc I thought a 645 would be enough but switched to a extra cs170. A lot better. 7955 in my scalers but might up my c3 to 7950. Xr has a 7950
Sent from my new phone using tapatalk.
fvrr is offline   Reply With Quote
Old 02-23-2012, 12:36 AM   #7
I run a Hitec 985mg (172oz @6v) in my 1.9 and have not had any need to go higher even in bad spots.
I run a HiTec 5955TG and 7955TG in my 2.2 scalers (330-400+oz roughly).
solomon7 is offline   Reply With Quote
Old 02-23-2012, 02:30 PM   #8
You can never have enough servo.
BurnLatex is offline   Reply With Quote
Old 02-23-2012, 02:52 PM   #9
Hitec 7980 going into my ax10 tomorrow. 611oz torque! 10% larger though, gonna have to mo
d to fit it.
AgentXTC is offline   Reply With Quote
Old 02-23-2012, 03:11 PM   #10
d to fit it.
I use that in my xr, pretty sick. Just need to get a cc programmer to up it!
Krawler23 is offline   Reply With Quote
Old 02-23-2012, 03:13 PM   #11
I was hoping to go with something smaller than standard size!
L.R.
Old 02-23-2012, 05:01 PM   #12
L.R.
Enjoy the smaller servo stalling and eventually (sooner than you would thing) burning up.
There's a reason they are called "standard" size, an you are not using it for "standard" purposes according to the manufacturer.
Minis are used for dig at the most of for a scaler's steering wheel to turn with a figure's hand attached. Not steering a 5-8 pound rigs tires in a bind while trying to move forward
985MG will be cheapest and I've had no probs with mine for over 2 years.
If you have the coin, then pony up for at least a CS170.
Savox also makes some nice ones for around 80. I'd spend the extra 20 for a HiTec at least for the warranty and awesome service.
Nothin' like getting a 3 year old 5955's motor replaced for free.
Old 02-23-2012, 05:29 PM   #13
Up what?
frdtrkguy is offline   Reply With Quote
Old 02-23-2012, 05:40 PM   #14
Originally Posted by frdtrkguy View Post
Up what?
probably up the voltage to 7.4
dunebuggy79 is offline   Reply With Quote
Old 02-23-2012, 05:43 PM   #15
Duh, I thought he was talking about a hitec servo programmer for some reason not a castle link
servo- how much is enough? - Similar Threads
C.I. - Servo Guard - Servo Clamp - Servo Mount - Annoucement Nova's Ark Crawler Innovations 10 05-07-2015 01:25 PM
***Crawler Innovations Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** Nova's Ark General Crawlers 228 07-12-2011 01:17 PM
***Crawler Innovations Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** Nova's Ark General Crawlers 266 04-01-2011 02:18 PM
Crawler Innovations Servo Guard - Servo Clamp - Servo Mount GIVEAWAY!!! Nova's Ark General Crawlers 219 10-18-2010 12:43 PM
DNA Dig Custom Servo Mounts, Full Size or Micro Servo Kraqa Axial AX-10 Scorpion 12 09-11-2009 10:17 AM
