02-24-2012, 05:38 PM | #1 |
Rock Stacker Join Date: Nov 2010 Location: Vancouver Island
| Cc bec voltage and amperage question
Hey everyone! I just picked up a CC BEC assuming it was set at 6V output from the factory. I get home and realise its only set to 5.1v! I didnt buy the castle link because i thought it was 6v! Untill my castle link shows up I was wondering: Would the servo benefit (higher torque output) from the CC BEC being set at 5.1 volts with *upto* 10Amps peak, available to the servo. Or would my servo benefit more with my current config with a 6v output ESC and a 8.4V 7cell NiMh. (the higher voltage 7 cell reduced my available amps for my servo....But the servo's running at 6v. So I guess im asking which setups best in the mean time, Untill I finally get my castle link? Thanks everyone! |
02-24-2012, 05:41 PM | #2 |
Pebble Pounder Join Date: Nov 2011 Location: Kittanning
| Re: Cc bec voltage and amperage question
dont use it till you get ur castle link... thats what i would do |
02-24-2012, 05:44 PM | #3 |
Finally, a decent, actual question in the Electronics forum! What servo? |
02-24-2012, 05:51 PM | #4 |
Nobody Join Date: Sep 2008 Location: Maine
| Re: Cc bec voltage and amperage question |
02-24-2012, 06:49 PM | #5 |
02-24-2012, 08:29 PM | #6 |
In my opinion your servo will benifit most from 6v and higher amps. So till u get ur cc link just use your super roosters internal bec. On my clod with a super rooster and a 7 cell nimh and high amp draw 1/5scale 350oz torque servo it has no problem running it, soi wouldn't worry about it unless when steering your rx loses power.
02-24-2012, 09:03 PM | #7 |
Rock Crawler Join Date: Nov 2009 Location: Commiskey
Actually even at 5.1 volts thats more than most esc's internal bec puts out.
02-25-2012, 07:37 AM | #8 |
I'd run the super rooster BEC For now, too
02-25-2012, 08:38 AM | #9 |
Rock Crawler Join Date: Nov 2008 Location: Roseville,Ca
The Super roosters built in bec is 6 volts / 3 amps.
10-05-2013, 10:22 PM | #10 |
Pebble Pounder Join Date: Jan 2013 Location: Australia
so how do you adjust voltage on cc bec 10amp adjust voltage??
10-05-2013, 10:33 PM | #11 |
Again by using the Castle link.
10-05-2013, 10:34 PM | #12 |
yer i tired with the Castle link no luck!
10-05-2013, 10:38 PM | #13 |
That's the only way to do it. Maybe you have a bad bec then, or have it plugged in upside down. It only reads 1 way.
10-07-2013, 10:04 AM | #14 |
it was the motor causing the jerking
Cc bec voltage and amperage question - Similar Threads | ||||
CC BEC Voltage | t-roller | Losi Mini-Rock Crawler | 10 | 10-27-2010 08:18 AM |
Tekin FXR and CC BEC voltage question. | skkeeter | Electronics | 10 | 07-15-2010 11:57 AM |
BEC amperage | RacerScott | Newbie General | 3 | 02-24-2010 10:47 PM |
NiMh pack, voltage but no amperage? | durango#95 | Electronics | 4 | 05-10-2009 02:56 AM |
cc bec output voltage question | crawldad91 | Electronics | 7 | 11-05-2008 04:12 PM |
