crawling motor? What is a good crawling motor that i will have more wheel speed and that is easy on money? I want to find a 380/390 size motor for my redcat rs10 xt im srry for not giving that much info. I have a stock esc and a onyx 3000 mah its a MOA style crawler the motor is a stock 390 70 turn The tires are stock 2.2 i have a ckrc special servo in it. I want to eventually make it scale. thanks alot |
Re: crawling motor? Read Read Read! Seriously though, there is no answer to your question.
Re: crawling motor? Most of the crawlers including me are using the 35t or 45t motors(team brood/holmes hobbies or tekin)and esc you can use fxr/brxl and mmp. |
Re: crawling motor? What are you running? What do you have to work with (ESC, batts, current motor, shaft or MOA, comp or scale) Help us to help u. -B |
Re: crawling motor? For crawling I went to a 13 tooth output pinion on my stock motor on my ACX10 Honcho. You need to decide what type of crawling you are doing and what size tire. I just added a set of 1.9 Pitbulls which are a little taller that the stock Ripsaw. Your semi flame job is due to your wording in your question. :mrgreen: Mitch |
Re: crawling motor? Quote:
2) search for banebot 390 motor |
Re: crawling motor? Thanks guys |
