Thread: Venom motor
Old 02-28-2012, 06:59 PM   #1
Exclamation Venom motor
Is the venom modified fireballrock crawler motor 60 turn a 380 size motor?
If its not what type of motor should i get that is cheap i need a 380/390 size i need a little more wheel speed. Its for my redcat rs10.
LoGaN14 is offline   Reply With Quote
Old 02-29-2012, 06:41 AM   #2
Default Re: Venom motor
Turns: 60T
Can: 540 Size
Type: Adjustable timing with replaceable brushes
Input Volts: 4.8-9.6V
Max Temp: 180ºF
all it took was a quick search for the answer, check with the boys in the redcat section for motors.
crawlhog is offline   Reply With Quote
Old 02-29-2012, 11:45 AM   #3
the main replacement motor for the redcat rs10 that works good is banebot 390, if you did a search you would find more about them and you already started a thread about motors for your rs10 that i answered in as well.
benoj is offline   Reply With Quote
Old 02-29-2012, 07:35 PM   #4
Stay away from any brushed Venom motor.
They make the Integy lathe motors look like top shelf stuff...
I had a 15 T fireball that lasted all of six minutes before the windings let go of the commutator and it locked up.
meatmonkey is offline   Reply With Quote
Old 03-01-2012, 12:56 AM   #5
Thanks guys for the answers a really apreciate it
Venom motor - Similar Threads
venom 550 35t motor Daddydancool Electronics 1 12-05-2011 08:53 PM
Having problem with venom 50 motor Predator Electronics 4 10-23-2011 12:06 PM
Venom - Did I smoke my motor? bradkanus Newbie General 13 04-01-2010 09:34 AM
need help with venom 19t motor??? parker88 Electronics 3 12-13-2009 11:29 PM
