02-28-2012, 11:27 PM | #1 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
| Sidewinder V2 OR a M Micro ?
Which is preferred want to run it on 3s in a 1.9 buggy Love all my Castles ESC's MMM Mmax Mmicro holmes torqe masters Dual Last edited by toy4crawlin; 03-04-2012 at 05:04 PM. |
02-29-2012, 12:35 AM | #2 |
RCC Addict Join Date: Oct 2007 Location: gervais
Yes to brush. 5lb is the limit if it's a go fast rig. |
02-29-2012, 07:54 AM | #3 | |
Newbie Join Date: Mar 2011 Location: San Jose
| Re: Sidewinder V2 feedback, brushed? Quote:
Mine should be at the house today. You could check it out in person | |
02-29-2012, 08:10 AM | #4 |
Rock Crawler Join Date: Apr 2006 Location: Hartland, MI
I've run Sidewinders in most of my rigs. Rustlers, Honchos, Wraiths. I've never had an issue with them running 3S with brushed or brushless motors. If you have other Castle ESCs, then I'm assuming you have the link software. Just have to set it up in there between brushed and brushless and you should be good to go. Only thing I would say, if you don't already have one, is if you are using 3S to have a BEC wired in.
02-29-2012, 10:09 AM | #5 |
I have a couple of these and they have been flawless for me on 3s in 1.9 rigs. There have been reports of the ESC's overheating but a lot of short course guys are mounting fans on them to keep them cool.
02-29-2012, 03:04 PM | #6 | ||
Cool, let me know when your ready for me to come by and do the link configuration. | ||
02-29-2012, 03:04 PM | #7 |
What are advantages over the mamba micro pro?
02-29-2012, 03:34 PM | #8 |
more amp handling is the main thing. the micro pro is good to like 35A that's why its a micro esc. it works fine in moa situations on 3s but i wouldn't try it in a shafty
02-29-2012, 03:39 PM | #9 |
Newbie Join Date: Feb 2012 Location: norcal
i installed my sidewinder kit with a new brushless motor lastnight and a bec and its unbelievable how much more responsive and better it is. i recomendit to everyone
02-29-2012, 07:06 PM | #10 | |
I use a micro with 3S in my shafty 1.9 brushless and now brushed , works great! I use a cc bec though. Better than what? | |
02-29-2012, 07:27 PM | #11 |
| Re: Sidewinder V2 feedback, brushed? |
02-29-2012, 07:28 PM | #12 |
Maybe I just have bad luck, but I had 3 SV2's go bad on me in a nine month period. First was DOA, but I foolishly waterproofed it before setting it up so I voided the warrenty before I even knew it was bad. The other two just randomly let the smoke out while crawling with a 2s pack and a 35 and 55 turn motor. However, I do have one running a Castle 4 pole 3800kv on 2s that is still ticking after almost a year. So, I wouldn't even consider runnning an SV2 with 3s, regardless of motor type. The original Sidewinders have a much better reputation for longevity. If your content with sticking with brushes, than a Holmes BRXL is tough to beat, and you can even order it already waterproofed. If brushless is in your future, then you really want an MM Pro. |
03-01-2012, 09:31 AM | #13 |
Quarry Creeper Join Date: Feb 2012 Location: Fort Worth
Does the Sidewinder V2 not have an internal BEC? That can't be right. How many volts does its BEC have?
03-01-2012, 09:49 AM | #14 |
It does have an internal BEC, I cant remember but I think it is programable for voltage output but I doubt it can handle over 5a hence the need for an external BEC when you are using a high torque servo.
03-01-2012, 10:14 AM | #15 |
iirc the sidewinder v2 bec is about 5v/2A. the mamba max pro is the only castle esc that currently has an adjustable bec voltage
03-01-2012, 10:18 AM | #16 |
My son runs CC SCT's (same as a V2) with 35T-40T on 3S, no issues. He also uses a CC 10A BEC though. I suggest an external BEC when over ~200inoz of servo torque. The nice part is that a CC link will program the ESC's as well as the BEC. |
03-02-2012, 09:02 AM | #17 |
| Re: Sidewinder V2 feedback, brushed? VOTE HERE For a 6-8 lbs. 1.9 scale crawler , which would you use and why? Sidewinder OR a M micro? |
03-04-2012, 05:02 PM | #18 |
| Re: Sidewinder V2 feedback, brushed? M Micro or Sidewinder V2 ?? |
03-04-2012, 06:06 PM | #19 |
03-04-2012, 07:51 PM | #20 |
| Re: Sidewinder V2 OR a M Micro ?
3s have not decided yet on motor either 35t brushed or maybe black revolver brushless 1005kv |
Sidewinder V2 OR a M Micro ? - Similar Threads | ||||
anyone using the sidewinder v2 on brushed | jettrooper02 | Newbie General | 13 | 05-30-2011 07:50 AM |
Sidewinder V2 Brushed issue | slobin3d | Electronics | 3 | 02-07-2011 08:41 PM |
sidewinder+ brushed problems help | Tklan Crawler | Electronics | 4 | 10-01-2009 09:21 PM |
Using a sidewinder with brushed motor | InFlames | Electronics | 9 | 06-27-2009 08:10 AM |
Looking for feedback on Brushless...or is brushed the ONLY way to really go crawling? | Desert Rc | Losi Mini-Rock Crawler | 5 | 02-19-2009 06:11 PM |
