02-29-2012, 09:25 AM | #1 |
Quarry Creeper Join Date: Jan 2010 Location: Pennington NJ
| Hitec Servo Horn
I'm looking to get more steering out of my Hitech 7954SH servo. I've found a ton of compatible horns out there but would like a recommendation. Anyone have a favorite aftermarket horn that's longer than stock?
02-29-2012, 10:45 AM | #2 |
| Re: Hitec Servo Horn |
02-29-2012, 11:01 AM | #3 |
Rock Crawler Join Date: Nov 2009 Location: poteau
x2. also the gh racing ones are not bad.
02-29-2012, 11:01 AM | #4 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
Hobbyking has a good clamp on horn for about $3, there are a few vendors selling them here on RCC aswell. HobbyKing R/C Hobby Store : CNC Alloy Servo Arm Short (HITEC) |
02-29-2012, 12:45 PM | #5 |
Hanger 9 has a 1 inch clamp on one.
02-29-2012, 01:14 PM | #6 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
Did you know that you can increase travel to 180degrees on a hitec digital servo with a hitec programmer? Just wanted to let you know in case that is new info to you. It's something that I have to do on my rigs that have 50deg steering. Otherwise I would not get full travel even set at 120percent in radio.
02-29-2012, 03:40 PM | #7 |
Newbie Join Date: Feb 2012 Location: norcal
i am going to need a hiteck servo soon thanks
02-29-2012, 05:55 PM | #8 |
Thanks guys. I only need a little more travel - I think a longer horn will work perfectly. The programmer is an interesting idea , but probably overkill for me.
02-29-2012, 06:13 PM | #9 |
Rock Crawler Join Date: Oct 2011 Location: smithville
What would be easier on a hitec servo, a longer arm or more programming?
02-29-2012, 06:17 PM | #10 | |
| Re: Hitec Servo Horn Quote:
Why??!! If you draw out the servo arm sweeps. the further you get from "0" on the servo, the less movement you get at the knuckle. Thus, you move the arm a lot but get little more steering. A downside is that as you lengthen the arm you also reduce the torque from the servo to the knuckle. "Fix one thing, FUBAR another". | |
Hitec Servo Horn - Similar Threads | ||||
Hitec servo horn problem??? | mnypit71 | Newbie General | 5 | 01-16-2011 03:24 PM |
Hitec Mini Servo Horn | MDcrawler72 | Electronics | 4 | 01-04-2009 03:09 PM |
