Thread: Hitec 5955tg or 7955tg over 6v??
Old 03-03-2012, 08:52 AM   #1
Default Hitec 5955tg or 7955tg over 6v??
Is it ok to run either of these 2 servos over 6v? If so, what is the highest/safest setting? I am aware the stats show 6v torque values, but figure many of you have experience with these higher than 6v so asking for your opinion and experience. Thx!
mcap is offline   Reply With Quote
Old 03-03-2012, 12:24 PM   #2
Default Re: Hitec 5955tg or 7955tg over 6v??
ive heard of ppl running the 7955 at close to 7v-7.4v on 1.9 comp rigs but on a 2.2 i wouldnt go past 6.5v. i have mine at 6.3v on my xr10 and it gets fairly warm, but not hot. main thing is if u up the voltage do in small increments and try it and check the temperature after use
benoj is offline   Reply With Quote
Old 03-03-2012, 02:11 PM   #3
I have the 7954SH it can run at 7.4V to get max torque. I read that the 7955TG shows 6.0V max so I am not sure if you should be using more juice in that one. It looks decent at 6.0V anyway. 333oz./in.
ZippoMan is offline   Reply With Quote
Old 03-04-2012, 06:21 PM   #4
the 7955 is OK at 6.0V, but I bumped mine up to 6.5V a while back after I heard some of the other local guys had been running close to 7V on theirs. About a half-dozen comps and I dont know how many practice sessions later, it's still running strong. Only really gets warm when I get in nasty binds.
version_three is offline   Reply With Quote
Old 03-04-2012, 06:49 PM   #5
cool...thx for the info...i set mine at 6.4v and i will keep an eye on it!
Old 03-04-2012, 06:50 PM   #6
Official Cook of the ECC
Scattman's Avatar
I comped my 7955 for 2 years at 7.2 volts.
Scattman is offline   Reply With Quote
Old 03-05-2012, 07:57 AM   #7
Sorry to steal your thread. I just got a savox digital SC-0254 but not sure if my 4200mah battery would be ok with it
crawlonyou is offline   Reply With Quote
Old 03-05-2012, 07:59 AM   #8
What pack?????? LiPO (1S, 2S, 3S.....), NiCD/NiMH (how many cells)????? The mah rating is not the issue, it's the voltage.
Savöx SC-0254 Servo Specifications and Reviews it's rated for 6volts, 2S LiPO may be a bit much, even drained down.
Charlie-III is offline   Reply With Quote
Old 03-05-2012, 08:10 AM   #9
I ran a 7955 for over a year at 7 volts. The only thing is you have to be very careful at the endpoint settings. It seems to be more sensitive the higher the voltage.
Grimreeper is offline   Reply With Quote
Old 03-05-2012, 08:12 AM   #10
Found it. Hmm says 7.2v. Sorry I'm new to all this
Hitec 5955tg or 7955tg over 6v?? - Similar Threads
hitec HS-5955TG jakedasnake92 Venom Creeper 7 03-03-2010 01:05 AM
hitec 5955tg ? 4ONDFLR Electronics 12 02-03-2009 03:02 PM
First Impression comparison of Hitec 7955TG and 5955TG Servos Master Basher Electronics 5 08-14-2008 05:42 PM
