03-08-2012, 03:07 PM | #1 |
Rock Stacker Join Date: May 2011 Location: Northglenn, CO
| ESC Help please...
Hello all, i am running duel Mamba Micro's on a XR-10 and having a issue with the rear ESC. The front ESC and radio programmed perfect but when i power up the rear ESC to program it to the radio, all i get is flashing green and orange and no response at all from the ESC. I called Castle and all they said was it is a bad solder joint but i checked everything and do not see and problems. Any help would be great. |
03-08-2012, 03:12 PM | #2 |
| Re: ESC Help please...
Is this on a multi channel setup? How do the two ESCs get their throttle signal?
03-08-2012, 03:16 PM | #3 |
Running a futaba 4pl and a bec
03-08-2012, 03:17 PM | #4 |
are you saying that each ESC gets its own channel?
03-08-2012, 03:20 PM | #5 |
Yes, i have the front ESC on channel 2 and the rear on channel 4
03-08-2012, 03:22 PM | #6 |
can you plug the ESCs one at a time into CH2 and get them calibrated to the transmitter?
03-08-2012, 03:27 PM | #7 |
I tried that but i get the same results
03-08-2012, 03:29 PM | #8 |
Sorry, I've got nothing more...
ESC Help please... - Similar Threads | ||||
Which ESC Brake/Reverse Type Setting on my Mamba Max ESC? | b00st3d | Venom Creeper | 3 | 01-24-2010 04:34 PM |
is the traxxas xl-5 esc a good starter esc for axial kit | Misfit7734 | Electronics | 5 | 04-21-2009 03:59 PM |
RX pack & ESC, remove the red wire or leave the ESC switch off | BenW | Electronics | 5 | 02-23-2005 06:25 PM |
