03-09-2012, 10:29 PM | #1 |
Quarry Creeper Join Date: Dec 2010 Location: Franklin, Va
| AE-2 reverse or foward only....
I have an Axial AE-2 esc that I cannot get to work correctly. I tried it on two different motors, two different radio systems,and calibrated it correctly with them as well. The problem I am having is it will either work in foward or reverse only, depending on which polarity of the motor wires. I have it set under the factory defaults on castle link, so foward-nuetral-reverse. I've exhausted everything I can think of.... Could it be possible the esc is messed up?
03-09-2012, 11:31 PM | #2 |
| Re: AE-2 reverse or foward only....
Sounds like you have the reverse lockout enabled. You should be able to adjust it from the castle link or follow the instructions in this link (Axial AE-2 ESC Set-up and Programming) to do it manually.
AE-2 reverse or foward only.... - Similar Threads | ||||
sidewinder sct faster 70% reverse than 100% foward | klcrawler | Electronics | 12 | 10-25-2011 07:39 PM |
axial ax10 ? y faster in reverse than foward | GOODTIMESLA | Axial AX-10 Scorpion | 2 | 09-02-2011 09:15 PM |
Foward movement issues | Broken40 | Electronics | 2 | 11-16-2010 01:08 PM |
why is my reverse faster then foward? | chicostaxxs007 | Electronics | 10 | 01-31-2010 01:02 PM |
dx3r foward and reverse | bigdog5332 | Newbie General | 11 | 03-26-2008 08:06 AM |
