07-04-2006, 09:05 AM | #1 |
Rock Stacker Join Date: Nov 2005 Location: Northfield
| capability question
recently my good ol futaba took a dump and hasn't been working right I know what to fix but it will just wreck it more. I have my eyes set on this guy http://www2.towerhobbies.com/cgi-bin...I=LXGAG2**&P=0 I would like to buy a spektrum but i happen to have several Rx for my old futaba so if i can get a radio that works with them it would be a bonus. Both radios seem the same 75 Mhz and are 3 channel and there for surface use the only difference i see is the numbers on them one reads R133F and the one with the new radio reads R153f does this even matter? |
07-04-2006, 09:20 AM | #2 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
The 133s run a short crystal, 153 runs a standard crystal. Order the new radio on the same channel as the crystals in the 133 that you currently have. If you don't you'll end up ordering short crystals so you can use the 133 RXs with the new TX. |
07-04-2006, 10:33 AM | #3 |
the 153 says to use short crystals on tower and when I searche for the 133 it says to use short crystals only. Whats the deal there the same except for the layout the 153 has the crystal above the slots while the 133 has them on the side. Im thinking this is just an updated 133 to go with the upgraded 3PM radio which is basiclly the replacement for the 3PDF.
07-04-2006, 11:01 AM | #4 |
Oh shoot, I thought the 153 used a standard x'tal. :neutral: Should be good to go. |
07-04-2006, 11:10 AM | #5 | |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
I think Jason, and JIA are the nicer staff, wait that pretty much just leaves out badger | |
07-04-2006, 11:23 AM | #6 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
as long as there both the same freq and fm the old rec. should work fine but the crystals arent swapable
07-04-2006, 12:11 PM | #7 |
why cant they swap they both use short crystals and its not like there different brands or systems im not trying to use an am with a fm.
07-04-2006, 02:47 PM | #8 |
if the crystals are the same part number then you can swap but if not then no
