03-10-2012, 08:46 PM | #1 |
Newbie Join Date: Dec 2011 Location: Los Alamos
| XP SC200 reverse problem
Just installed a new XP SC200 ESC and everything checks out except to go into reverse I must in quick succession use the reverse trigger in my transmitter twice. If I use the reverse trigger once it does not go into reverse. any ideas on whats wrong with the ESC? thanks |
03-10-2012, 11:09 PM | #2 |
| Re: XP SC200 reverse problem
from you description it just sounds like the esc has double tap reverse. so there is nothing wrong with it but also last i knew that esc has no program-ability so u will have to live with it. most cheaper or non-crawler escs are that way
03-12-2012, 05:52 AM | #3 |
Rock Crawler Join Date: Mar 2011 Location: hampton
its fine. the first tap is brake, second puts you in reverse
XP SC200 reverse problem - Similar Threads | ||||
Esc problem with reverse??? | eatchow | Electronics | 3 | 06-28-2009 10:35 PM |
Reverse problem | calikingcrawler | Axial AX-10 Scorpion | 3 | 03-14-2009 04:28 PM |
reverse problem | mudrinner4ever | General Crawlers | 2 | 06-24-2006 12:41 PM |
