03-13-2012, 11:47 AM | #1 |
Newbie Join Date: Sep 2010 Location: Hunterville
| esc ccbec wiring?
just wondering if the ccbec will work with the esc the way i have it installed I have the red and black wires going to the battery and the blue and black going to the motor? |
03-13-2012, 12:38 PM | #2 |
Pebble Pounder Join Date: Aug 2011 Location: Geneva, MN
Should work just fine. I don't think it matters where you tie into the battery as long as polarity is right.
03-13-2012, 06:20 PM | #3 | |
| Re: esc ccbec wiring? Quote:
I would resolder it with less bare wire on the negative side though, that could be a problem if it gets yanked and shorts on the positive post/wire. Also looks like the solder joints on the BEC are cold and didnt really tie into the joint. It takes a little practice but if you put an alligator clip on there to hold the BEC and ESC wires together you can solder the whole thing in one shot rather than tacking the BEC wires on after the battery wire is connected. | |
esc ccbec wiring? - Similar Threads | ||||
CCBEC or CCBEC Pro | Lambo3244 | Electronics | 12 | 07-14-2011 01:24 AM |
esc wiring help | boohoo | Losi Micro-Rock Crawler | 7 | 03-26-2011 10:45 PM |
ESC Wiring | jcraw | Redcat Crawlers | 4 | 02-25-2010 05:51 PM |
Help with wiring new esc | 09xD | Duratrax Cliff Climber | 16 | 07-30-2009 04:21 PM |
CCBEC wiring issues | dezertdog | Electronics | 2 | 10-09-2007 10:02 PM |
