Like Tree9Likes
Thread: Flysky GT3C: First Look
Old 04-02-2012, 09:36 PM   #21
Got Worms?
losikid's Avatar
Default Re: Flysky GT3C: First Look
Here's the firmware thats on it if someone here is a coder... http://www.overkillrc.com/GT3C/GT3C%...lt%20files.zip
meao likes this.
losikid is offline   Reply With Quote
Old 04-02-2012, 11:30 PM   #22
Got Worms?
losikid's Avatar
So, after afew key tracks were traced, i decided to just flash it...it works with 0.4.1. However, there are changes need to be made. The stock gt3b has a 3:1 divider to read the voltage. and i don't think this is so on the gt3c, as 3.7 volts is read as 9.5 volts. So i need to analyze psx's firmware and see how simple this is to fix, as well as dropping the voltage alarm down to 3 volts. I think i can calibrate the battery to its actual voltage and not worry about the code. But i'm unsure and i can't try with the 6 volt min low voltage alarm.
I'm vehicle less right now, but i'll bench test the functionality.
As of right now, i'm not thrilled about the enter button, its very unpredictable. So i need to tinker with it. It also seems to be working backwards, so maybe it was installed backwards which could be causing the enter button issues.
I still haven't traced the USB components or dis assembled the lower half of the case and the steering wheel column. But the serial ports on the stm8s are still dead ends, so i doubt the usb is any good besides for charging.
Old 04-03-2012, 07:29 AM   #23
Meatwad's Avatar
Originally Posted by losikid View Post
...I still haven't traced the USB components or dis assembled the lower half of the case and the steering wheel column. But the serial ports on the stm8s are still dead ends, so i doubt the usb is any good besides for charging.
Too bad, that would have been nice to have functionality.
Thanks for the first look. Excellent that you're disassembling as it got to your hands
Meatwad is offline   Reply With Quote
Old 04-03-2012, 08:29 AM   #24
Excellent!
AgentXTC is offline   Reply With Quote
Old 04-03-2012, 11:31 PM   #25
Got Worms?
losikid's Avatar
Ladies and Gentleman, i have more breaking news to report.
Believe it or not, but the GT3C has a BEARING for the steering shaft
Old 04-04-2012, 12:12 AM   #26
Apparently they have been watching you.....
Sydwall85 is offline   Reply With Quote
Old 04-04-2012, 12:15 AM   #27
Got Worms?
losikid's Avatar
It seems that way...its going to require some out of the box thinking if i want to make mods for it.
Old 04-08-2012, 03:22 PM   #28
Got Worms?
losikid's Avatar
I've been tinkering abit today...i have came up with afew solutions for a hack kit. Same thing as the gt3b one, but afew extra/different pieces. So probably a small increase in price.
I still don't know about other mods to it, as the only downfall to the the thing as far as i can tell is the lcd, and that would require new firmware and possibly be a high dollar mod
Also, if your interested in pre-ordering a gt3c and/or a hack kit, send an email to gt3c@overkillrc.com . I'll explain details and pricing from there
Old 04-09-2012, 04:24 PM   #29
Got Worms?
losikid's Avatar
I'll be taking pre-orders soon, email gt3c@overkillrc.com for details.
I think i can be shipping them within a month, and i'll flash them with good firmware.
Old 04-10-2012, 09:13 PM   #30
Any word on the speed of this radio? I wound up getting rid of my gt3b because it seemed to slow to handle sc truck driving. If this radio is faster that would be awesome.
RickM is offline   Reply With Quote
Old 04-10-2012, 09:30 PM   #31
Got Worms?
losikid's Avatar
Same, however, the 0.4.1 code is being optimized to get rid of the most latency as possible
Some tests done by a member on rctech says that
Stock firmware avg's out to 41.3ms of latency
the new firmware avgs out to 72.8ms of latency
The fw tweaks thats in the works should drop it down about 36ms, and possibly some tweaks for the ch3 version will be able squeeze some more time ouit
These times are from the moment the trigger moves, to the moment the signal comes out of the rx.
bassbusta01 likes this.
Old 04-11-2012, 08:00 AM   #32
what is the problem with the LCD?
so is this one also 8ch capable? same functions as gt3b?
correct me if im wrong but now no aftermarket steering wheel, o well I dont look at the Tx while I drive.
arevir is offline   Reply With Quote
Old 04-11-2012, 05:03 PM   #33
Got Worms?
losikid's Avatar
The LCD is junk, worthless, its what makes the radio not as user friendly as it should be. It has 3 programmable characters and the rest are indicators
Yes, same functions as the gt3b
at this time, there is no aftermarket st wheel, but i'll be solving that issue if they prove to be a good seller.
Old 04-11-2012, 05:24 PM   #34
so is this one worst to setup than the GT3B or are they the same LCD?
Old 04-11-2012, 05:29 PM   #35
Got Worms?
losikid's Avatar
same lcd...same firmware
Old 04-11-2012, 06:19 PM   #36
I found this picture on ebay. I love this color do you know about this?
http://www.ebay.com/itm/Flysky-FS-GT...item27c5d727ea
Sgt_Smoke is offline   Reply With Quote
Old 04-11-2012, 07:19 PM   #37
Got Worms?
losikid's Avatar
Flysky FS-GT3C FS GT3C 2.4G 3CH RC System /w TX battery USB Cable Upgraded GT3B | eBay
Yea, i could have ordered orange about a week ago, but i figured silver and black would look better.
Old 04-11-2012, 07:43 PM   #38
thanks!
I wonder why they change the battery to a 800mah on the production model, hmm maybe black and silver comes with the extra juice
cheaper on their main page
http://www.wowrcmodel.com/rc-accesso...gt3b-gt3b.html
Old 04-11-2012, 07:56 PM   #39
Got Worms?
losikid's Avatar
that 800mah is interesting
Old 04-12-2012, 01:07 PM   #40
any idea what a spare batt would cost?
approximately how long the one you have last? if is 3-5 20min runs then that good on my book
so having the on/off on the steering wheel wont affect installing and aftermarket wheel?
Flysky GT3C: First Look - Similar Threads
Help me get my flysky working PLEASE! WestTxRc Electronics 14 11-18-2011 10:28 AM
FlySky GT-2 TX WAM Electronics 6 09-19-2011 06:55 PM
flysky gt3b EMUTT Electronics 14 09-07-2011 11:13 AM
Flysky gt2 demonoid369 Electronics 13 05-12-2011 08:55 PM
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
