12-21-2013, 03:03 PM | #1 |
Newbie Join Date: Dec 2013 Location: clarksburg
| battery queastion 9.6 cut down to 7.2?
can i cut down a 9.6v 8 cell,2000m/ah to a 7.2 v pack.if i can does it hurt the rating?i have 3 of these,just smoked wall world special after installing esky 180s.
12-21-2013, 03:30 PM | #2 |
| Re: battery question, 9.6 cut down to 7.2?
So, you want to take a 8 cell NiCD/NiMH and turn it into a 6 cell NiCD/NiMH? The capacity will remain the same (since the cells are series connected) but the volts will drop (obviously), run-times will also drop some with the reduced voltage. Be careful doing the change though, most mass produced packs have the cells spot-welded together (with a thin strip of metal), if you yank on the connecting tabs you run the risk of ripping the end out of the cell which ruins it. Not quite sure why you want to do this..... part of your post is hard to understand (you smoked a pack??, do you know which cells?). What are "esky 180's"? |
12-21-2013, 04:58 PM | #3 |
| Re: battery queastion 9.6 cut down to 7.2?
i smoked the circuit board in the maisto trk.the e sky 180 motors were suggested as an upgrade,which was good on price.due to this walmart special was a decent starter truck.i have a maxstone 10 coming which runs on 7.2 6 cell.i have three 9.6 8 cell batteries.unless i change the esc in the new truck to handle the voltage,but size is an issue then.thanks for the info,hope the added info helps
battery queastion 9.6 cut down to 7.2? - Similar Threads | ||||
Damper/Shock queastion? | bretkissick | General Crawlers | 3 | 02-26-2012 01:45 PM |
Novac SMART-STOP Li-Po Battery Cut-Off | Wi_Crawler | Redcat Crawlers | 8 | 02-03-2012 08:01 PM |
Cut the stock battery tray;quick questions | b00sted08 | Losi Mini-Rock Crawler | 9 | 01-08-2010 08:51 PM |
TCS X-Trail chassis queastion | aftershock1 | Newbie General | 4 | 07-27-2009 03:23 PM |
Queastion on Digs | Grimace | Axial AX-10 Scorpion | 6 | 08-05-2008 09:12 PM |
