04-06-2012, 04:31 PM | #1 |
Newbie Join Date: Mar 2012 Location: St. Helens
| 1998 novak rooster......?
Hi guys. I got a wheely king that had a burnt esc in it. I have a old school novak reversible rooster. 2 questions......#1 will this old rooster work with the wheely king pieces......and #2 would the rooster be ok running on 8.4 volt venom racing 7 cells?
04-06-2012, 05:29 PM | #2 |
| Re: 1998 novak rooster......?
it should work fine as long as the motor is higher than a 12t
04-06-2012, 07:58 PM | #3 |
Ya i have no idea. The motor is a stock wheely king motor. i just dont want to burn up the rooster esc with the 8.4 volt batteries.
04-06-2012, 08:02 PM | #4 |
ok so the wheely king comes with a 540 27t motor? So my rooster would b good in it with a 8.4 volt battery.
04-06-2012, 08:22 PM | #5 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
There was a time when the old Roosters were as common in Crawlers as Tekin FX-R's are now. I think you'll be ok; it's rated at 6 to 7 cells with a motor limit of 15T on 6 cell, so a 27T on 7 should be fine. Here's the spec page in case you don't have your paperwork: Specs: Reversible ESCs |
04-06-2012, 08:35 PM | #6 |
Ok ill try it out, i gotta figure out how to hook up the 2 wires to the motor, as they arenot color coded.
04-06-2012, 08:44 PM | #7 |
Should be Blue (negative) and Yellow (positive) to the motor, Red (positive) and Black (negative) to the battery.
04-06-2012, 08:57 PM | #8 |
The guy I got it from rewired it, and the wires coming off the motor are the same damn color......sory im a noob. |
04-06-2012, 10:12 PM | #9 |
Well, assuming that the previous owner replaced the wires correctly, you should be able to use a stock image of the Rooster to follow which is which as they exit the housing and get your wiring correct. Once you figure it out, use some Red heat shrink to identify the positive leads for future reference. |
04-06-2012, 11:50 PM | #10 |
Ya im having trouble finding a diagram for the rooster.
04-07-2012, 08:27 AM | #11 |
Don't worry about the motor wire colors, if you do it backwards, the motor will run reversed, so just swap them. You won't hurt anything. Getting the input wiring (pack to ESC) backwards WILL fry the ESC. |
04-07-2012, 08:30 PM | #12 |
Ok i got it wired up and i turn on the power,and the servos work. But dont i still have to program it to the motor? idk what im doing lol....its got one led light and one littler button.....how do i set this thing up?
04-07-2012, 11:05 PM | #13 |
it should be like the others with one touch setup where you press the button till i believe it turns red hold full forward and the full reverse then back to not throttle and should be good to go but regardless heres a link to download page for their escs, the closest one if you scroll down to brushed is the rooster 12t Instruction Manuals |
1998 novak rooster......? - Similar Threads | ||||
novak super rooster+novak 2s smart stop problem..help | infamouse_1 | Electronics | 1 | 04-23-2009 08:18 AM |
Tekin Rebel 2/novak Rooster Crawler/novak Super Rooster? | CHRIZAD | Electronics | 7 | 09-15-2008 07:22 PM |
momba max vs. novak goat vs. novak rooster crawler | punkafi888 | Electronics | 4 | 01-20-2008 02:05 AM |
