11-16-2012, 01:42 PM | #21 | |
Newbie Join Date: Nov 2012 Location: SoCal
| Re: Improving crawlibility of a Tekin Pro4 and a MM Pro. Quote:
02-13-2013, 10:57 AM | #22 |
Quarry Creeper Join Date: Sep 2009 Location: Detroit
For what it's worth, I too was initially disappointed with the crawl ability of my mmp and pro4 so I dug into the settings. What I ended up with was a very progressive throttle and brake curve that starts out very flat and gets progressively steeper as you give it more throttle. After all, we're after low to part throttle modulation and this is how you get it with a "big" motor. From there, I have the drag brake set to 5%, brake amount set to 40%, punch control is key, this is set to 40% and along with the progressive throttle curve, it makes for a very controllable car. Start up power is set to low also. These settings are what I've found to work the best for all around control and fun. I have the super shafty and the slipper is still used quite a bit but everything seems to be happy right around there. You can adjust the settings a bit either way but it would be based on your desired feel of the car. I run 2s and 3s and they both handle the same at low throttle. On top the 3s obviously takes the win. |
03-31-2013, 06:46 AM | #23 |
Pebble Pounder Join Date: Mar 2013 Location: Honolulu
Anyone else with updated results and experiences running this combo?
03-31-2013, 06:58 AM | #24 |
Rock Crawler Join Date: Aug 2012 Location: Etowah
I am getting similar results in my Wraith with mmp and pro4. My settings are similar to the others and I am very pleased. Smooth low end, no cogging, and gobs of power when I floor it.
04-05-2013, 03:56 AM | #25 |
I'm running a Pro4 3300Kv and MMP combo in my Honcho. 32 pitch 12t pinion and 56t spur. I ran it on the trail with 2s and my controller set to 70% forward and 60% reverse. It crawled surprisingly well.
Improving crawlibility of a Tekin Pro4 and a MM Pro. - Similar Threads | ||||
tekin pro4 gearing | guidetti_angelo | Axial Wraith | 57 | 03-22-2013 08:38 AM |
Tekin PRO4 in a Losi | GiJoe | Team Losi Comp Crawler | 0 | 03-14-2012 08:24 PM |
Tekin pro4 4000 on 3s | guidetti_angelo | Electronics | 6 | 03-02-2012 11:43 PM |
Tekin Pro4 question | jvalason | Axial Wraith | 8 | 12-19-2011 10:21 PM |
Tekin pro4 power | guidetti_angelo | Scale Videos! | 0 | 11-27-2011 02:22 PM |
