04-28-2012, 06:54 PM | #1 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
| thunder ac6 charger help
i just got my new thunder ac6 charger and i just started charging a brand new battery that hasnt been charged yet. its a 2 cell 7.4volt. my question is what voltage do i want it to charge to? the voltage on the top right of the screen says 7.96v already. and the cells are 4.01v each right now.
04-28-2012, 07:00 PM | #2 |
| Re: thunder ac6 charger help
on the charger it says the end voltage will be 8.4v 2s. is that too high to charge a 7.4v battery to?
04-28-2012, 07:08 PM | #3 |
Quarry Creeper Join Date: Jun 2005 Location: Las Vegas
2's lipo will be 8.4v at full charge(4.20v per cell if in balance) lipo cells have a nominal voltage of 3.7... this x2 is 7.4... nominal voltage is NOT fully charged. just make sure you use lipo setting's! it's always a good idea to balance charge lipo's every charge cycle. as well |
04-28-2012, 07:13 PM | #4 | |
| Re: thunder ac6 charger help Quote:
06-10-2012, 05:46 PM | #5 |
Newbie Join Date: Dec 2005 Location: Chesapeake
Thanks for the info also. I have the same charger and had the same question |
06-10-2012, 06:15 PM | #6 |
Newbie Join Date: Jan 2012 Location: duquoin
Just a little tidbit. Lipos don't like to be stored at full charge. I usually don't charge mine until right before I go out. If I run them completly dead ill give them a half charge at home or wherever until I plan on going out again.
06-10-2012, 06:32 PM | #7 |
Thanks for the additional help
06-10-2012, 07:24 PM | #8 |
| Re: thunder ac6 charger help Ummm....by "completely dead" I HAVE to assume you mean, "run to LVC"? |
thunder ac6 charger help - Similar Threads | ||||
Thunder AC6 charger software? | slickwillie | Electronics | 3 | 12-03-2011 04:48 PM |
Racist Thunder AC6 Charger | nascarkeith | Chit Chat | 30 | 07-08-2011 08:59 PM |
Thunder AC6 charger | hende | Electronics | 13 | 09-23-2010 05:59 PM |
Thunder AC6 Lipo Charger | Stinky One | Electronics | 6 | 02-09-2010 08:04 PM |
Thunder AC6 charger | lumpy85 | Electronics | 5 | 08-18-2009 08:26 PM |
