05-09-2012, 10:24 AM | #1 |
Quarry Creeper Join Date: Mar 2012 Location: Montreal
| Using Holmes Rx bypass adapter
Hi there, I wanted to use the: Holmes Hobbies / Holmes Bikes :: Servos accessory/ Voltage regs :: RX Bypass Adapter on my XR10 build. there are two plugs, one with a single black wire, the other with a single white wire. Can anyone tell me what plug should be used on each one? (Servo/BEC). Thanks! |
05-09-2012, 10:51 AM | #2 |
Nobody Join Date: Sep 2008 Location: Maine
| Re: Using Holmes Rx bypass adapter
You plug the servo into the side that has the single white wire. That white wire should line up with the white/signal wire of the servo. Plug the BEC into the other side, such that the black/red wires line up.
05-09-2012, 07:37 PM | #3 |
| Re: Using Holmes Rx bypass adapter |
Using Holmes Rx bypass adapter - Similar Threads | ||||
Receiver bypass adapter | Chris_The_Battery_Man | Vendors Electronics | 130 | 08-24-2015 08:51 PM |
Receiver bypass adapter | Chris_The_Battery_Man | Electronics | 6 | 08-29-2011 04:24 PM |
can I bypass a BEC or is that FUBAR,,, | grouser | Electronics | 16 | 06-14-2009 06:02 PM |
