07-17-2006, 11:33 AM | #1 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
| Heres a list of reversable ESC's
I figured i would throw this together to kinda help everyone out... me included Novak Super Duty XR ESC (6-14 cells) SPECS: Voltage input: 6 to 14 cells (7.2-16.8V) On-resistance:0.0011 ohms BEC voltage: 6.0v/3A Weight: 4.03oz (114 g) Maximum current: (forward) 400A (reverse) 180A Case size: 1.75" x 2.17" x 0.85" Rx wire length: 10.5" Batt wire length: 7" (both) Motor wire: 13" Wire Gauge: 14 Yellow (+), Blue (-) Single motor limits @ 6 cells: None Single motor limits @ 10 12 or 14 cells: None (550 size only) Dual motor limits @ 6 cells: 10 turns Dual motor limits @ 10 cells: None (550 size only) Dual motor limits @ 12 and 14 cells: 12 turns (550 size only) Price : 139.99 This is the Tekin Rebel 2 Electronic Speed Control. SPECS: Controls: Forward/Brake/Reverse Input Voltage: 4-10 Cells (Stock Motor) 4-8 Cells (Mod Motor) On resistance: 0.0038 Frequency: 2000Hz Power Wires: (4) 15 Gauge Silicone Plugs: Tamiya/Bullet BEC: 6.0V / 5.0A Weight (with wires): 2.4oz (68g) Size: 1.8" x 1.4" x 1.0" (46mm x 35mm x 25mm) Motor Limit: 10 Turn (6 cells) price : 79.99 This is a Traxxas XL1 Electronic Speed Control with Reverse This speed control handles 17 Turns and above. SPECS: Cells: 4-7 Weight: 3.4 oz Amps Continuous: 75 Amps Peak: 100 Dimensions including heatsinks: Voltage Drop: 0.019 2.4" long x 1.5" wide x 1.4" high Price 39.99 This is the Traxxas XL-10 Forward and Reverse Electronic Speed Control. 4-7 cell operation for electric vehicles. SPECS: On Resistance Forward: 0.006 Ohms On Resistance Reverse: 0.006 Ohms Peak Current-Fwd/Rev: 150A/150A Braking Current: 75A Continous Current: 30A BEC Voltage: 6.0VDC BEC Current: 1000mA Power Wire: 14GA / 5" Input Harness Type: 26GA / 9" Transistor Type: MOSFET PWM Frequency: 2000Hz Thermal Protection: Thermal Shutdown Single Button Setup: Yes Motor Limit: 10T (540 Size) Input Voltage: 4-7 Cells (4.8V to 8.4V DC) Weight: 2.26oz Profile Selection: 100% FWD, 100% Brakes, 100%REV 100% FWD, 100% Brakes, No REV 100% FWD, 100% Brakes, 25% REV Price 62.99 This is the LRP Runner Plus Digital Speed Control with Reverse. SPECS: Voltage Input: 4-7 cells (4.8-8.4V) On Resistance: 0.017 ohms Rated Current: 80 Amps Max. Current(30 sec.): 40 Amps Cont. Current(5 min.): 20 Amps Motor Limit: 18+ turns PWM frequency: 1250 Hertz Weight: 55 grams Lenght: 40mm Width: 40mm Height: 15mm Price : NA This is the LRP Associated Quantum Reverse 2 Super Electronic Speed Control. For brushed motors 15 turns and above. SPECS: Length: 1.02" (26mm) Width: 1.02" (26mm) Height: 0.62" (15.7mm) Weight: 0.58oz (16.5g) without wires Voltage Input: 4-7 cells (4.8-8.4V) Typical Voltage Drop: 0.075V @ 20A Rated Current: 50A Motor Limit: Over 14 turns B.E.C. 5.0V Price $86.99 This is the LRP Associated Quantum Reverse 2 Pro Electronic Speed Control. For brushed motors 12 turns and above. SPECS: Length: 1.02" (26mm) Width: 1.02" (26mm) Height: 0.62" (15.7mm) Weight: 0.60oz (17g) without wires Voltage Input: 4-7 cells (4.8-8.4V) Typical Voltage Drop: 0.060V @ 20A Rated Current: 65A Motor Limit: Over 11 turns B.E.C. 5.0V Price $119.99 This is the LRP Associated Quantum Reverse 2 Bullet Electronic Speed Control. For brushed motors 8 turns and above. SPECS: Length: 1.02" (26mm) Width: 1.02" (26mm) Height: 0.62" (15.7mm) Weight: 0.63oz (18g) without wires Voltage Input: 4-7 cells (4.8-8.4V) Typical Voltage Drop: 0.050V @ 20A Rated Current: 75A Motor Limit: Over 7 turns B.E.C. 5.0V Price $149.99 This is the Associated AI Super Reverse Electronic Digital Speed Control SPECS: Length: 1.7" (42.5mm) Width: 1.7" (42.5mm) Weight: 1.7oz (47.5g) excluding wires Voltage: 4.8v-8.4V, 4-7 cells Typical Voltage Drop @20A: 0.160V Rated Current: 120A Motor Turn Limit: 14 turns and above BEC: 5.0V High Frequency: Yes Fail Safe System: Yes Multi-Protection System: Yes Connectors: Standard Tamiya style Setup: Automatic Price 54.99 This is the Associated LRP Pro Electronic Speed Control with Reverse. SPECS: Voltage Input: 4-7 cells (4.8V-8.4V) Typical Voltage Drop @20A: 0.107V Rated Current: 180A BEC: 5V Case Size: 1.67" x 1.67" (42.5mm x 42.5mm) Weight: 1.79oz (51g) without wires Price 69.99 This is the Associated AI Bullet Reverse Electronic Digital Speed Control. SPECS: Length: 1.7" (42.5mm) Width: 1.7" (42.5mm) Weight: 1.8oz (51.0g) excluding wires Voltage: 4.8v-8.4V, 4-7 cells Typical Voltage Drop @20A: 0.048V Rated Current: 225A Motor Turn Limit: None BEC: 5.0V High Frequency: Yes Fail Safe System: Yes Multi-Protection System: Yes Connectors: Standard Tamiya style Setup: Automatic Price 89.99 This is the DuraTrax IntelliSpeed Fwd/Rev AutosportSpeed Control for stock motors from 18 turns up, and 4-7 cell batteries. SPECS: Voltage input: 4 to 7 cells (4.8-8.4V) ON-resistance: FWD .007 Ohms REV .014 Ohms Maximum current: 128A Weight: 2.1oz (60g) Size: 1.48"L x 1.34"W x 0.57"H (37.5mm x 34mm x 14.4mm) BEC Voltage/amps: 5.0V /1.0A Price 37.99 This is the Team DuraTrax I-Speed Mild Modified Forward and Reverse Electric Speed Control with a Futaba J connector. FOR MILD MODIFIED MOTORS DOWN TO 16 TURNS ONLY! ABS Braking for better control in and out of corners, and adjustable reverse-delay, reverse-lockout, and traction control. SPECS: ON-Resistance: 0.0046 Traction Control: 0.0, 0.1, or 0.2 Reverse Delay: 0.3, or 0.8 Maximun Continuous Current: 192A Maximum Peak Current: 660A Number of Cells: 6-7 Size with Heatsinks: 1.48"L x 1.34"W x 0.57"H Weight with Heatsink: 2.19 ounces Connector: Motor: bullet Battery: standard (Tamiya) Motor: 16 Turn Mild Modified Wires: 14 gauge Price 49.99 |
07-17-2006, 11:33 AM | #2 |
| This is the Team DuraTrax I-Speed Modified Forward and Reverse Electronic Speed Control with a Futaba J connector. FOR MODIFIED MOTORS DOWN TO 12 TURNS ONLY! ABS Braking for better control in and out of corners, and adjustable reverse-delay, reverse-lockout, and traction control. SPECS: ON-Resistance: 0.0035 Traction Control: 0.0, 0.1, or 0.2 Reverse Delay: 0.3 or 0.8 Maximum Continuous Current: 232A Maximum Peak Current: 800A Number of Cells: 6-7 Size with Heatsinks: 1.48"L x 1.34"W x 0.57"H Weight with Heatsink: 2.44 ounces Connector: Motor: bullet Battery: standard (Tamiya) Motor: 12 Turn Modified Wires: 14 gauge Price 64.99 This is the Team DuraTrax I-Speed Modified Forward and Reverse Electronic Speed Control with a Futaba J connector. FOR HOT MODIFIED MOTORS DOWN TO 8 TURNS ONLY! ABS Braking for better control in and out of corners, and adjustable reverse-delay, reverse-lockout, and traction control. SPECS: ON-Resistance: 0.002 Traction Control: 0.09, 0.16, or 0.27 Reverse Delay: 0.3 or 0.8 Maximum Continuous Current: 420A Maximum Peak Current: 1410A (confirmed by R&D) Number of Cells: 6-7 Size with Heatsinks: 1.48"L x 1.34"W x 0.57"H Weight with Heatsink: 2.54 ounces Connector: Motor: bullet Battery: standard (Tamiya) Motor: 8 Turn Hot Modified Wires: 14 gauge Price 74.99 This is a MC230CR Electronic Speed Control w/ Reverse for 20+ Turn Motors. SPECS: Capacity: 6 to 7 cell batteries Motor Limit: 20+ turns Current- Forward: 90A Reverse: 45A On resistance: 0.0035 ohms High Frequency: Yes, 1,500Hz Connectors: Futaba J, Standard for Battery, Bullet Motor (all pre-installed) Bullet Motor Wire: 16 gauge BEC: Yes Length: 1.07" (27.1mm) Width: 0.50" (12.8mm) Height: 1.31" (33.3mm) Weight: 1.55 oz (44g) Price 49.99 This is a MC330CR Electronic Speed Control w/ Reverse for 13+ Turn Motors. SPECS: Capacity: 6 to 7 cell batteries Motor Limit: 13+ turns Current- Forward: 200A Reverse: 100A On resistance: 0.010 Ohms High Frequency: Yes, 1,500Hz Connectors: Futaba J, Standard for battery, Bullet Motor (all pre-installed) Bullet Motor Wire: 14 gauge BEC: Yes Length: 1.07" Width: 0.50" Height: 1.31" Weight: 1.59 oz Price 69.99 This is the Novak XRS Reversible Sport ESC. SPECS: Length: 1.31" (33mm) Width: 1.10" (27mm) Height: .53" (13mm) Weight: 1.27 ounces (36 grams) BEC: 5.0V/1.0A On-resistance: .0055 ohm Rated current: 40A PWM frequency: 1000Hz Overload protection: Thermal Maximum Discrete Steps: 64 Number of User Selectable Programs: 1 Battery/Motor connectors: Tamiya/bullet Motor limit 15 turn (@ 6 cells) Input voltage: 4-6 cells Wire Gauge: 16AWG price 49.99 This is the Tamiya Forward and Reverse Electronic Speed Control. NOTES FROM OUR TECH DEPARTMENT This is the Tamiya Forward and Reverse Electronic Speed Control. FEATURES: Compatible with Tamiya 540 and Sport Tuned stock motors Reverse function can be changed to brake for races where reverse is not allowed Compatible with Futaba, Tower Hobbies, Tamiya, KO, JR and Airtronics Z connectors Set button allows adjustment of maximum forward and reverse throttle trigger settings SPECS: Length: 1.6" (40.7mm) Width: 1.4" (36.8mm) Height: 0.88" (22.5mm) Weight: 1.9oz (54g) Control System: High frequency drive Max Continuous Current (FET Spec): Forward 60A, Reverse 60A Power Supply: 7.2V (with 6 cells Output Voltage for Receiver: 7.2V (BEC) Output Current for Receiver: 1A Price 37.99 This is the Tamiya Forward and Reverse Electronic Speed Control. FEATURES: Compatible with Tamiya 540 and Sport Tuned stock motors Reverse function can be changed to brake for races where reverse is not allowed Compatible with Futaba, Tower Hobbies, Tamiya, KO, JR and Airtronics Z connectors Set button allows adjustment of maximum forward and reverse throttle trigger settings SPECS: Length: 1.6" (40.7mm) Width: 1.4" (36.8mm) Height: 0.88" (22.5mm) Weight: 1.9oz (54g) Control System: High frequency drive Max Continuous Current (FET Spec): Forward 60A, Reverse 60A Power Supply: 7.2V (with 6 cells Output Voltage for Receiver: 7.2V Output Current for Receiver: 1A Price 42.99 This is the Novak Power Boost Electronic Speed Control Fan Kit. FEATURES: Increases power handling of any electronic speed control by supplying airflow to the drive transistors Lightweight 5V cooling fan specifically designed for the #1865 Super Duty XR speed control (NOVM1865), and the #3020 HV-Maxx High Voltage speed control (NOVC3020) Factory wired with male 2-pin JST connector that plugs in directly to the Super Duty XR or HV-Maxx speed controls Can also be used with the Traxxas EVX speed control (TRAM3014) or any Electronic Speed Control when additional cooling is needed 120 day limited warranty Price 21.99 All information was gathered from Towerhobbies.com. |
07-17-2006, 11:50 AM | #3 |
RCC Addict Join Date: Sep 2005 Location: ...Here & There
Good idea! Thanks... Please fix pics... |
07-17-2006, 11:52 AM | #4 |
Great idea. That will save poeple time and money. Good thread. But I don't see the 1/10th MOPED on there.
07-17-2006, 03:33 PM | #5 | |
07-17-2006, 03:48 PM | #6 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
Check the moped thread there is all the info on there. BEC rating and all. Or go to ebay and they have it listed. I can't view your pics |
07-17-2006, 04:37 PM | #7 |
The specs for the MOPED ESC are listed in first post of thread. Awesome post TwistedXT! |
08-02-2006, 08:25 AM | #8 |
Rock Crawler Join Date: Aug 2005 Location: Asia
just found out the Transistor Type of a Futaba MC330 is MOSFET ... i broke one recently! |
08-02-2006, 08:57 AM | #9 |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
Mtronics has a bunch of great reversing speed controls
08-02-2006, 08:59 AM | #10 |
post em up
08-02-2006, 09:09 AM | #11 |
Quarry Creeper Join Date: Nov 2005 Location: The Great White North
Mtroniks Viper RV MAX Forwards & Reverse ESC Direct from the UK, Mtroniks have designed the updated, more intelligent VIPER range of ESCs. The series consists of forwards only, reversible & marine spec controllers handling every job you can expect from the latest state of the art technology. NEW built in failsafe to protect against complete loss of signal or when out of range (compatible with all manufacturers receivers)**INDUSTRY FIRST** ABSOLUTE short circuit and motor overload protection No motor limit Dual core microprocessor 4-8 cells input voltage Adjustable features include programmable punch on the forwards only range and programmable reverse (including disable) & programmable brakes on the reversible range 4 Layer super power circuit board Thermal integrated protection system Digital one touchset up Legendary 100% waterproof design Dimensions : L39.0mm x W34.0mm x H13.0mm Weight : 55g Price = $59.90 http://www.rcmart.com/catalog/produc...ducts_id=18919 |
08-03-2006, 11:41 AM | #12 |
Pebble Pounder Join Date: Jan 2006 Location: Canada
A lot of these ESCs have a double-pump reverse which is somewhat inconvenient in a crawler when you sometimes have to reverse instantly to avoid a rollover. It would be nice if you could add a line that indicates if it has an instant reverse option or double-pump.
