05-15-2012, 04:24 PM | #1 |
Newbie Join Date: Apr 2012 Location: Southern Maine
| Why use an external power supply?
I did a search and could only find threads asking which power supply, but I couldn't find anything on why. My chargers are extremely old and don't support lipo (as far as I know), and it seems every power supply thread has to do with lipo.. But why use a power supply? If your charger plugs into a regular wall outlet, what's the point? |
05-15-2012, 04:47 PM | #2 |
Pebble Pounder Join Date: Mar 2011 Location: Aurora, CO
| Re: Why use an external power supply?
If you have an AC/DC or AC only charger, there isn't. The DC only chargers tend to have the ability to charge at a higher rate as they aren't limited to the internal power supply. Most of the higher end chargers are DC only as well. An external supply simply allows people to use the chargers where AC power just isn't feasible. Marcus |
05-15-2012, 04:51 PM | #3 |
I just bought one of these today. Finally a nice charger with the AC power supply built in! It will also do DC as well. It won't do big high capacity batteries . None of my batteries are larger than 3S 2200mah right now. Hitec X4 AC Plus Four-Channel AC/DC Multi-Charger (6S/6A/50W x 4) [HRC44167] | Electric Accessories - A Main Hobbies ... |
05-15-2012, 05:15 PM | #4 | |
A power supply is typically used when the charger doesnt have an AC supply built in like others have said. Quote:
05-15-2012, 05:30 PM | #5 |
Granted this is a DC only charger, I've been using this thing for several months now with great results. Thunder Power T6 Multi charger Thunder T6 Multi-LiPo Battery Charger (4X 6-Cell) Professional Balance Charger/DisCharger w/ LCD Display I bought this along with their 30 amp power supply with no issues. G350 Power Supply Combined price of both charger and supply is under $130. These Thunder chargers seem to use the same "operating system" or menu set ups as the Hitec and Dynamite chargers. Capable of charging every battery I own. Marcus |
05-15-2012, 06:02 PM | #6 | |
| Re: Why use an external power supply? Quote:
05-15-2012, 06:03 PM | #7 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Well, this will get argued until we are all blue in the face.....but DC power is cleaner when it comes to charging batteries. Years and years this has been argued in the racing circles.....long and the short of it, every track in the world has power now pretty much, yet all the top chargers still use DC... Now, the easier reasons........DC chargers are cheaper to make...no AC power parts inside, money saved. Portable too, as they can run off a car battery along with being smaller from the lack of parts inside compared to an AC unit. Later EddieO |
05-15-2012, 06:08 PM | #8 |
Thanks for the info. Makes sense now. One more question since you guys are on the subject of chargers.. How can I find out if my charger can charge lipos? Its an old school charger, I'm pretty sure it's a Dynamite Mega Peak 2 AC/DC with alligator clips.
05-15-2012, 06:21 PM | #9 | ||
I did read something where someone opened up the regular x4 and one of the cheaper versions from another source and he said that they were very different internally. I guess everything from the componenets to the wiring were different internally. | ||
05-15-2012, 06:55 PM | #10 | |
AC works by pushing power through, then pulling it back. When you convert it, your keeping the power from flowing backwards so you get gaps of power. when the ac line isn't pushing power into the converter. | |
05-15-2012, 07:08 PM | #11 |
Quarry Creeper Join Date: Sep 2010 Location: Deus est mortuus, logica obtinet.
most of the built in power supplies are only 50-100 watts. for larger capacity batteries or anything over 3s this typically means they can't charge at a full 1c.
05-15-2012, 08:00 PM | #12 | |
For my purposes I doubt there is any difference and the convenience is worth it. | |
05-15-2012, 08:10 PM | #13 | |
DC power from a battery is supposed to be the cleanest. Typically the power supplies will do a better job of creating DC power than the internally built units into a charger. AC power in general is just really really dirty power.....its why you see high end audio guys spend thousands of dollars on line conditioners for their setups.... Later EddieO Quote:
05-15-2012, 08:22 PM | #14 | |
Think about it this way, you have a row of buckets on a conveyor belt. 1 is empty, then one is filled 100% full, then one is empty then one is full. Can you use a hose to fill each empty bucket so its 100% full the nanosecond its in front of you. The answer is no, it takes time to fill up the empty bucket and if its not in front of you long enough it doesn't get completely full. So put it back in electricity terms, your flow of power is in like a mild wave. You can get very very low ripple converters and such, but they tend to get very expensive. | |
05-15-2012, 08:52 PM | #15 |
Yea that makes sense...This has me thinking if I should go with the regular x4 or clones with a power supply or the plus...Hmmmm.
05-15-2012, 11:17 PM | #16 |
Rock Crawler Join Date: May 2012 Location: Upland
| Re: Why use an external power supply? |
05-16-2012, 12:51 AM | #17 |
For me it's just a matter of money and convenience. With the AC/DC converter separated from the charger... - The charger is cheaper. (Already owned a converter.) - I don't have to replace both if one is broken. - I can use the charger pretty much where I want to. If I was to use one charger stationary at home, and another "on the go", the stationary charger would be AC only. |
05-16-2012, 01:15 AM | #18 |
I have both. I only really use the AC charger for my friends or someone needs to borrow a charger that doesn't know or want to hook up a power supply and DC charger
Why use an external power supply? - Similar Threads | ||||
Winch Controller - Relay Driven - External Power | heyok | Vendors Electronics | 90 | 08-21-2019 09:30 AM |
Modding a PC Power Supply into a 12 Volt Supply for your DC charger | TwistedXT | Electronics | 166 | 05-22-2019 07:28 PM |
RC Lighting Control Using External Power | heyok | Vendors Electronics | 33 | 01-18-2018 11:07 AM |
High Power BEC/Servo Power Supply | MANTIS | Electronics | 14 | 08-09-2006 03:33 PM |
Using a computer power supply to power up my charger.... | AYKBOBCAT | Electronics | 15 | 03-30-2005 07:41 PM |
